Scholar embedded
Can't select xc7a50t for EDK project
I can't select xc7a50t2csg324 in EDK project. I have only two choices xc7a100t and xc7a200t while there are other parts of Artix family. I am using EDK14.7. Is there any software update for it?
Thanks in advance,
Hossein
Scholar sampatd
Re: Can't select xc7a50t for EDK project
hi,
refer to page 8 of the http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_5/irn.pdf
if you are using ISE Webpack then it is an expected behavior.
--hs
Scholar embedded
What should I do then? Isn't there any update?
How about newer versions of ISE? Is it planned to continue in the future versions of ISE as well?
Scholar sampatd
14.7 was the last of ISE releases. For 7-series devices, please move to Vivado.
Scholar embedded
Will I have the ability of choosing all 7-series family members there?
How about EDK projects? Can I import my projects from EDK14.7 into the Vivado?
I am not familiar with it. I am wondering if there's a quick start for Vivado?!
Scholar sampatd
Scholar embedded
Hi @sampatd and @htsvn,
Thank you both very much for your guidance. I am going to switch to Vivado in the near future as I am planning to use Artix-7 35 in one of my projects. Thank you @sampatd for your comprehensive links and information.
Hossein
