Cannot build BSP in XSCT (bug?), Ubuntu LTS
I've run into an issue with the new XSCT tools (Vivado 2015.1) in Ubuntu 14.04 LTS.  I'm running XSCT with a script using the -s switch.  XSCT is able to build the hardware design, but fails during BSP generation.  This is the SDK.log file that's generated:
10:51:12 ERROR :  [Hsi 55-1545] Problem running tcl command ::sw_standalone_v5_0::post_generate : couldn't execute "mb-ar": no such file or directory
    while executing
"exec $archiver -d $libgloss_a _interrupt_handler.o"
    (procedure "::sw_standalone_v5_0::post_generate" line 18)
    invoked from within
"::sw_standalone_v5_0::post_generate standalone"
 [Hsi 55-1443] Error(s) while running TCL procedure post_generate()
10:51:12 ERROR : Error generating bsp sources: Failed to generate BSP.
So, though my Xilinx tools are sourced, "mb-ar" cannot be found.  "which mb-ar" from the terminal command line returns "/opt/Xilinx/SDK/2015.1/gnu/microblaze/lin/bin/mb-ar", and XSCT appears to be looking in the right place:
xsct% mb-ar
couldn't execute "/opt/Xilinx/SDK/2015.1/gnu/microblaze/lin/bin/mb-ar": no such file or directory
mb-ar does exist at that location on my machine, but as a symbolic link.  Could this be a permissions problem?
This all works in Fedora 22.
Here's the XSCT script:
set SDK_WORKSPACE sw
set HW_DEF hw/hw.runs/run_1/bd_wrapper.hdf
set HW_PROJ bd_wrapper_hw
set SA_BSP_PROJ standalone_bsp
set APP_PROJ app_standalone
# set the SDK workspace
sdk set_workspace $SDK_WORKSPACE
# create the hardware outputs in SDK
sdk create_hw_project -name $HW_PROJ -hwspec $HW_DEF
# create the standalone BSP
sdk create_bsp_project -name $SA_BSP_PROJ -hwproject $HW_PROJ -proc microblaze_0 -os standalone
# create application
sdk create_app_project -name $APP_PROJ -hwproject $HW_PROJ -proc microblaze_0 -bsp $SA_BSP_PROJ
# build the application
sdk build_project
exit
hi,
can you confirm if you are able to compile BSP using GUI?
--hem
That was the problem.  Thank you!
