marcoventurini
Cannot build Zynq BSP with xilisf 2016.4
I'm  trying to build a BSP with the xilixsf library enabled with the 2016.4 toolchain
After exporting the hardware we try to compile the BSP and we get the following error:
'SpaMicWinDevices' undeclared (first use in this function)    xilisf.c    /standalone_bsp_0/ps7_cortexa9_0/libsrc/xilisf_v5_7/src
I found some other reference to this issue but no real answer,
What should I do?
Marco
smcnutt
Hi Marco,
This is an old PITA that AFAIK still isn't fixed. See this post. You can set your bsp settings (xilisf serial_flash_family) to winbond (4) or spansion (5) if that's what you're using. Otherwise, I suppose you can edit the conditionals in your project. I've done as much in a pinch.
--Scott
