Participant mrpackethead
Cannot find --llwip4 SDK2018.2
I'm creating a new application project;
I select freertos10_xilinx as the OS Plaform, and then FreeRTOS IwIP Echo Server.
when it trys to compile it fails.    See errors.
No modifications where made to anything.
Re: Cannot find --llwip4 SDK2018.2
Have you included the corresponding libraries in SDK?
In SDK, right-click on your bsp sup-project, click Board Support Package Settings, then tick the library:
Hi, thanks yes, i have
If i create a standalone project,  ( not freertos ) it will compile, with Lwip.
Interesting, for FreeRTOS not being much more than a bunch of files to add.
Hard coded path somewhere?
Please switch the tab to Console and paste the error message that you are getting . If possible provide the HDF file also ?
Raju
here are the builds for both the bsp and the project.  and system.hdf is attached as  a zip file.
the bsp wont' compile, whjich appears to be related to the file   xemacliteif.c
its trying to include lwip/timers.h   which it cant' find   and also it can't include stdio.h  and string.h
Any help would be greatfully received.
20:18:41 **** Build of project freertos_lwip_bsp ****
make -k all
"Running Make include in microblaze_0/libsrc/bram_v4_2/src"
make -C microblaze_0/libsrc/bram_v4_2/src -s include "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Running Make include in microblaze_0/libsrc/cpu_v2_7/src"
make -C microblaze_0/libsrc/cpu_v2_7/src -s include "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Running Make include in microblaze_0/libsrc/emaclite_v4_3/src"
make -C microblaze_0/libsrc/emaclite_v4_3/src -s include "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Running Make include in microblaze_0/libsrc/freertos10_xilinx_v1_1/src"
make -C microblaze_0/libsrc/freertos10_xilinx_v1_1/src -s include "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"include"
"Running Make include in microblaze_0/libsrc/gpio_v4_3/src"
make -C microblaze_0/libsrc/gpio_v4_3/src -s include "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Running Make include in microblaze_0/libsrc/intc_v3_7/src"
make -C microblaze_0/libsrc/intc_v3_7/src -s include "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Running Make include in microblaze_0/libsrc/lwip202_v1_1/src"
make -C microblaze_0/libsrc/lwip202_v1_1/src -s include "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Running Make include in microblaze_0/libsrc/tmrctr_v4_4/src"
make -C microblaze_0/libsrc/tmrctr_v4_4/src -s include "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Running Make include in microblaze_0/libsrc/uartlite_v3_2/src"
make -C microblaze_0/libsrc/uartlite_v3_2/src -s include "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Running Make libs in microblaze_0/libsrc/bram_v4_2/src"
make -C microblaze_0/libsrc/bram_v4_2/src -s libs "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Compiling bram"
mb-ar: creating ../../../lib/libxil.a
"Running Make libs in microblaze_0/libsrc/cpu_v2_7/src"
make -C microblaze_0/libsrc/cpu_v2_7/src -s libs "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Compiling cpu"
"Running Make libs in microblaze_0/libsrc/emaclite_v4_3/src"
make -C microblaze_0/libsrc/emaclite_v4_3/src -s libs "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Compiling emaclite"
"Running Make libs in microblaze_0/libsrc/freertos10_xilinx_v1_1/src"
make -C microblaze_0/libsrc/freertos10_xilinx_v1_1/src -s libs "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Compiling standalone";
microblaze_sleep.c: In function 'usleep_MB':
microblaze_sleep.c:106:29: warning: unused parameter 'useconds' [-Wunused-parameter]
int usleep_MB(unsigned long useconds)
microblaze_sleep.c: In function 'sleep_MB':
microblaze_sleep.c:128:32: warning: unused parameter 'seconds' [-Wunused-parameter]
unsigned sleep_MB(unsigned int seconds)
microblaze_sleep.c: In function 'MB_Sleep':
microblaze_sleep.c:153:19: warning: unused parameter 'MilliSeconds' [-Wunused-parameter]
void MB_Sleep(u32 MilliSeconds)
"Compiling FreeRTOS"
"Running Make libs in microblaze_0/libsrc/gpio_v4_3/src"
make -C microblaze_0/libsrc/gpio_v4_3/src -s libs "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Compiling gpio"
"Running Make libs in microblaze_0/libsrc/intc_v3_7/src"
make -C microblaze_0/libsrc/intc_v3_7/src -s libs "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Compiling intc"
"Running Make libs in microblaze_0/libsrc/lwip202_v1_1/src"
make -C microblaze_0/libsrc/lwip202_v1_1/src -s libs "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Compiling lwip src and adapter files"
contrib/ports/xilinx/netif/xadapter.c: In function 'eth_link_detect':
contrib/ports/xilinx/netif/xadapter.c:366:8: warning: unused variable 'link_speed' [-Wunused-variable]
u32_t link_speed, phy_link_status;
contrib/ports/xilinx/netif/xemacliteif.c:65:10: fatal error: lwip/timers.h: No such file or directory
#include "lwip/timers.h"
compilation terminated.
make[1]: *** [xemacliteif.o] Error 1
make[1]: Target `libs' not remade because of errors.
make: *** [microblaze_0/libsrc/lwip202_v1_1/src/make.libs] Error 2
"Running Make libs in microblaze_0/libsrc/tmrctr_v4_4/src"
make -C microblaze_0/libsrc/tmrctr_v4_4/src -s libs "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Compiling tmrctr"
"Running Make libs in microblaze_0/libsrc/uartlite_v3_2/src"
make -C microblaze_0/libsrc/uartlite_v3_2/src -s libs "SHELL=CMD" "COMPILER=mb-gcc" "ARCHIVER=mb-ar" "COMPILER_FLAGS= -O2 -c -mcpu=v10.0 -mlittle-endian -mxl-soft-mul" "EXTRA_COMPILER_FLAGS=-ffunction-sections -fdata-sections -Wall -Wextra"
"Compiling uartlite"
make: Target `all' not remade because of errors.
20:19:02 Build Finished (took 20s.249ms)
20:19:02 **** Build of configuration Debug for project freertos_lwip ****
make all
'Building file: ../src/echo.c'
'Invoking: MicroBlaze gcc compiler'
mb-gcc -Wall -O0 -g3 -c -fmessage-length=0 -MT"src/echo.o" -I../../freertos_lwip_bsp/microblaze_0/include -mlittle-endian -mcpu=v10.0 -mxl-soft-mul -Wl,--no-relax -ffunction-sections -fdata-sections -MMD -MP -MF"src/echo.d" -MT"src/echo.o" -o "src/echo.o" "../src/echo.c"
'Finished building: ../src/echo.c'
'Building file: ../src/iic_phyreset.c'
mb-gcc -Wall -O0 -g3 -c -fmessage-length=0 -MT"src/iic_phyreset.o" -I../../freertos_lwip_bsp/microblaze_0/include -mlittle-endian -mcpu=v10.0 -mxl-soft-mul -Wl,--no-relax -ffunction-sections -fdata-sections -MMD -MP -MF"src/iic_phyreset.d" -MT"src/iic_phyreset.o" -o "src/iic_phyreset.o" "../src/iic_phyreset.c"
'Finished building: ../src/iic_phyreset.c'
'Building file: ../src/main.c'
mb-gcc -Wall -O0 -g3 -c -fmessage-length=0 -MT"src/main.o" -I../../freertos_lwip_bsp/microblaze_0/include -mlittle-endian -mcpu=v10.0 -mxl-soft-mul -Wl,--no-relax -ffunction-sections -fdata-sections -MMD -MP -MF"src/main.d" -MT"src/main.o" -o "src/main.o" "../src/main.c"
'Finished building: ../src/main.c'
'Building target: freertos_lwip.elf'
'Invoking: MicroBlaze gcc linker'
mb-gcc -Wl,-T -Wl,../src/lscript.ld -L../../freertos_lwip_bsp/microblaze_0/lib -mlittle-endian -mcpu=v10.0 -mxl-soft-mul -Wl,--no-relax -Wl,--gc-sections -o "freertos_lwip.elf" ./src/echo.o ./src/iic_phyreset.o ./src/main.o -Wl,--start-group,-lxil,-lfreertos,-lgcc,-lc,--end-group -Wl,--start-group,-lxil,-llwip4,-lgcc,-lc,--end-group
c:/xilinx/sdk/2018.2/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-elf/7.2.0/../../../../microblaze-xilinx-elf/bin/ld.exe: cannot find -llwip4
collect2.exe: error: ld returned 1 exit status
make: *** [freertos_lwip.elf] Error 1
20:19:03 Build Finished (took 1s.289ms)
Nobody knows how to fix this?
I can't say I've used 2018.2 but I've used lwip and FreeRTOS on 2017.4. Can you share your system.mss file as I would hazard a guess it might be an lwip configuration issue somewhere. Failing that it could be a problem with the TCL for generating LWIP but it might take me a minute to track down where that file lives
The Mss file might highlight something so if you can share that first I'll take a look
Simon
Also is there a timers.h file showing in the following folder:
bsp_name/CPUName/libsrc/lwip202_v1_1/src/lwip-2.0.2/src/include/lwip
First two folder names will reflect your design. Some of the lwip names I've had to infer based on my older installation.
If the file is not there then check the following folder (assuming default installation path for Xilinx (if not change folders accordingly):
C:\Xilinx\SDK\2018.2\data\embeddedsw\ThirdParty\sw_services\lwip202_v1_1\src\lwip-2.0.2\src\include\lwip
If the file is missing from there then you have a bigger problem (which may require a re-installation or there is a bug in 2018.2 that has omitted the file). This is the source folder that is used to copy driver files from when it creates the BSP
Let me know how you get on with that and I'll see if I can suggest anything else
Simon
Hi Simon, if you see above; there is an attachment system.zip. I had to zip it so I could attach it as it woud't let me post the mss file directly.
i dont' have the timers.h in that folder.
That is odd.
I just checked on the instlalation of 2018.2 on my laptop, which has had no work done.. It too is missing the file.  In the version 2.0.2 lwip files, its missing, but in the 1.41 version it is there.
For what its worth LWip without FreeRTOS appears to use quite a differnet set of files.
Hmm, sounds a bit odd. If the source file is not there in the installation directory, it doesn't sound like you'd have much hope of it ever working. Might be worth opening a support ticket with Xilinx on that one.
Failing that try searching that folder tree (C:\Xilinx\SDK\2018.2\data\embeddedsw) to see if that timers.h file appears anywhere else?
 Just had another thought. I've just downloaded the lwip source zip for 2.0.2 and there is no timers.h file in there either. There is a file called timeouts.h though, which appear to contain almost exactly the same thing as timers.h. Is this included in the installation folder?
If it is, can you change the #include in the xemaclite.c to point to timeouts.h and see if that works? Might be worth a go. It might be a bug in the xemaclite driver and that needs to be updated
Simon
Thanks for that, it compiled, but it does'nt seem to want to work.
Sounds like you have similar issues to this thread:
https://forums.xilinx.com/t5/Embedded-Development-Tools/Cannot-build-application-with-LwIP-2-0-2-FreeRTOS-10-on-Vivado/m-p/909181/highlight/false#M47467
Pop over to that thread and have a look. Between us we should be able to work out what is going on.
I'll help where I can but I haven't upgraded to 2018.2 yet (still on 2017.4). It almost feels like there is something in the xilinx emaclite port of LWIP that needs to be upgraded to Lwip 2.0.2 but hasn't been properly tested.
I'll see if I can see anything in the lwip changelogs that might throw some light on the matter
Simon
This issue is fixed in 2018.3, for a patch on 2018.2 please refer the following AR
https://www.xilinx.com/support/answers/71330.html
Raju
