Cannot lauch SDK 2018.3 on Ubuntu 16.04
I was tryting to launch SDK and got the following errors:
Error appeared on prompt:
" The configuration area at '/home/hl/.Xilinx/SDK/2018.3' could not be created. Please choose a writable location using the '-configuration' command line option."
Error from terminal:
 "Launching SDK with command /home/hl/xilinx/SDK/2018.3/eclipse/lnx64.o/eclipse -vmargs -Xms64m -Xmx4G -Dorg.eclipse.swt.internal.gtk.cairoGraphics=false &"
I have tried export SWT_GTK3=0 , it did not work for me.
Re: Cannot lauch SDK 2018.3 on Ubuntu 16.04
I figured it out.
Change permission to .Xilinx solved the problem
I figured it out.
