cvpeck
Cannot stop MicroBlaze. Stalled on instruction fetch. PC=0x8
Hi all,
pulling my hair out here.
I have a simple Vitis project which runs fine. However if I try to create a new software project instead to run using the same hardware, the new software project fails to run, even if I substitute the original code into the new project. They both use the same hardware specification file.
I've checked memory maps, driver versions, everything seems to be the same. A basic hello_world application fails in the same way, yet my original code runs fine.
Error while launching program:
I'm thinking there must be some configuration option that is different between the two projects which causes it to fail but I am at a loss.
Can anyone provide any advice as how to chase this one down?
THanks,
Chris
