Cannot write AXI traffic generator registeres with standalone driver.
My design is containing a traffic generator IP. I try to set up from a C code from microblase with the following code (part).
uint32_t *tafGenbasePtr = XPAR_AXI_TRAFFIC_GEN_0_BASEADDR;
len = 5+i;            // 0 = 1
transferCnt = 2+i;    // 0 = inf
XTrafGen_SetStreamingTransLen(xtrafGenptr , len);
XTrafGen_SetStreamingTransCnt(xtrafGenptr , transferCnt);
It works for the first time, but when I call these macros multiple times, the register value remain unchanged, or become totally wrong.
If I use native register writes like the following:
len = 5+i;            // 0 = 1
tafGenbasePtr[XTG_STREAM_TL_OFFSET/4] = (transferCnt<<16)+len;
works fine also writing several times.
I use
  • Vivado 2016.3 (legacy reasons)
  • Win 7
  • VC707 devboard
Re: Cannot write AXI traffic generator registeres with standalone driver.
Hi @betontalpfa
Could you share your macro definitions to check where the error is? I also guess that each time you are calling to the function/macro you increment the value of i?
Ibai
Ibai
Hi @ibaie
Yes, this is a test and I modify the 'i' in each loop iteration.
The macro is located in the xtrafgen.h header.
Here is the "fully expanded" version of the macro in my case (len=5):
(Xil_Out32((((xtrafGenptr)->Config.BaseAddress) + (0x38)), (((Xil_In32((((xtrafGenptr)->Config.BaseAddress) + (0x38)))) | 05))))
