Change referenced hardware platform of a BSP
Our software is required to support n hardware platforms.
How can I change the hardware platform of a BSP?
Is it possible to have more than one hardware platform?
if I have more than one hardware platform, do I have to create a BSP for every platform?
And if it's possible, can I reference more than one hardware platform in our application project.
We're using XSDK 2018.3.
thanks and cheers!
Re: Change referenced hardware platform of a BSP
Hi @fbruder,
It's not possible to change the Hardware Platform of a BSP. Indeed, you could change the HDF file of a Hardware Platform Project:
Yes, you could have as many Hardware Platform Project as you want in your SDK working space.
Exactly.
No.
So the conclusion is you have to create a different Application Project for each Hardware Platform Project you have.
I think the reason behind all of your above questions, is to not multiply your source code in different places. If so, then you could put all of your source files in a separate location, and just link to that folder in your Application Project.
To do so, create a new folder either by a right click on your Application Project folder> New> Folder or from the main menu> New> Folder:
Then:
Best regards,
Abdallah
Hi @fbruder,
Exactly.
No.
Then:
Best regards,
Abdallah
thanks for your answer.
Not quite what I hoped for but ok.
My intension was to not have that manny projects in my workspace.
I think it gets really confusing because we have 3 application projects in our workspace.
If the BSP sources would be in C++, the hardware platforms could be namespaced and exist in one BSP.
Thanks and cheers!
