sin
Changing from xilkernel to Freertos
Hi I am trying to change a project from xilkernel to freertos. I am getting this error in sleep.h. Please advise.
marcb
Hi @sin
Can you try resetting the BSP sources and compiling again?
Using an example RTOS application, I can see that usleep is declared in the standalone library within the xil_sleepcommon.c file. Is this accessible within the platform?
marcb
Hi @sin
