zuwashi
Clock generator and clock synthesys
Hi Everyone,
I have a small problem with my design. I have an External clock source at 105 mhz. I need 3 clocks in my system: 26.25mhz, 26.25 mhz (whit a 90 degree phase shift) and 6.5625mhz.
when i try to synthesize the system, i get an error. This is the content of clock_generator_o.log:
Clock generation result : FAILED
C_FAMILY = virtex4
C_CLKIN_FREQ = 105000000
C_CLKFBIN_FREQ = 0
C_CLKFBOUT_FREQ = 0
C_CLKFBOUT_BUF = TRUE
C_CLKOUT0_FREQ = 26250000
C_CLKOUT0_PHASE = 0
C_CLKOUT0_GROUP = NONE
C_CLKOUT0_BUF = TRUE
C_CLKOUT1_FREQ = 26250000
C_CLKOUT1_PHASE = 90
C_CLKOUT1_GROUP = NONE
C_CLKOUT1_BUF = TRUE
C_CLKOUT2_FREQ = 6562500
C_CLKOUT2_PHASE = 0
C_CLKOUT2_GROUP = NONE
C_CLKOUT2_BUF = TRUE
ERROR:
CLKOUT1 can not be generated alone from the clock input
I can't explain why, since I have no problem when i set the clock values to 100,100 (with 90 phase shift) and 25 Mhz.
I have also tried to generate some of the clock using an additional DCM (several different configuration), but i get timing constraints error.
Thanks for your answers.
golson
I think the problem is likely that you are creating too slow a frequency for the Clock Generator.  You could use logic to create your slow clocks from a higher frequency clock.  You did say you were able to create a 25 mhz clock though.  What chip family are you targeting.  I think that 6 Mhz would probably be too slow.
Also there is a related posting: Which says the M/D ratio may not be able to match the frequency you are trying to achieve.
http://forums.xilinx.com/t5/Embedded-Processing/convert-ucf-pl-missing-Spartan6-option/m-p/122624#M3941
zuwashi
Thanks for your answer.
I don't think the problem is in the frequency.
The report i posted in the previous post tells that the clock that is causing the problem is C_CLKOUT1, not C_CLKOUT2 (and btw you can synthetize it by setting N = 2 and D = 32).
The problem is in the phase shift, but i can't understand why.
