Code and Data options in "Generate Linker Script" ?
  I am using EDK to control a crypto-block. The peripheral parts has a DDR2_SDRAM because I need to input a large amount of plaintexts as the inputs and meanwhile stores the encrypted ciphertexts in memory. So I used DDR2 as the memory location.
   I am using XIo_Out8(XPAR_AES_IO_0_BASEADDR+0x1, Din++) to wirte the plaintext to slv_reg0 and crypto-block will generate the ciphertext to slv-reg1. So I use DataOut = XIo_In32(XPAR_AES_IO_0_BASEADDR+0x4) to read the ciphertexts out.
and it works OK.
One point I am not sure is that in "generate linker script", one of the option is "Place data sections in". If I choose "DDR2" but not "ilmb_cntlr_dlmb_cntlr", Does it mean that the ciphertexts can therefore be store in external memory DDR2?  If it is, why when I was using "DataOut = XIo_In32(XPAR_DDR2_SDRAM_MPMC_BASEADDR)", I can only read data FFFFFFFF from DDR2 ? but not the right ciphertexts?
Pls offer me some hints, Thanks!!
  Eric,
Re: Code and Data options in "Generate Linker Script" ?
If u choose .data section in DDR2 it means that only data section of ur code will be on ddr2 ie if declare any int array soome thing like this
Inr data[10]={1,2,3,...} this array will be on DDR2
 if u need to tarnfer whole ur cipher text then just declare a pointer
int *cipher[]=DDR2_SDRAM_ADDR
now ur cipher text will be on ddr2
regards
JOY
