Code grayed out even though define set
I am using the serial flash lib and have defined a Spansion type in the lib cfg (2018.1 SDK). But when I look at the code in the lib files it is grayed out. The XPAR_XISF_FLASH_FAMILY is defined so I dont really understand what the issue is. Thanks
/* Xilinx EDK In-system and Serial Flash Library (XilIsf) User Settings */
#define XPAR_XISF_FLASH_FAMILY 5
#define XPAR_XISF_INTERFACE_AXISPI 1
Try the following from the menu:
Project->C/C++ Index->Rebuild (or freshen all files)
I've had a similar issue in the past when I know something is definitely defined but the GUI says otherwise.
Of course that may not be the problem but it has worked for similar things to me in the past
Simon
Hello @beandigital,
XPAR_XISF_FLASH_FAMILY being defined is not enough.
You should check if it matches any of INTEL, STM, WINBOND, SPANSION, or SST value. If any of the mentioned parameters has value of 5, then this block should not be grayed out. You check that, simply hover your mouse cursor on each of them to see their values.
\Razi
-- Don’t forget to Reply, Kudo, and Accept as Solution --
Simon, thanks but that didnt work
Razi, it does match the SPANSION value. When I debug the code it goes into that code, its just that its displayed grayed out
@beandigital
It's likely due to the optimization level.
The higher the optimization level, the more difficult it becomes for SDK to display the debug info.
You will also likely see when single stepping it goes all over the place.
Hi @beandigital,
Did you solve the issue? or just you are able to live with it? I'm quite interested if you found what was going wrong.
Ibai
Ibai
I've seen the same thing in my SDK 2018.2 project using xilisf libarary v5.8.
Somehow the project is not seeing the xparameters.h file (referenced in xilisf.h), which is where XPAR_XISF_FLASH_FAMILY and XPAR_XISF_INTERFACE_XXX defines are set during generate BSP sources.
All the paths to includes and libs are set in project but the code is still grayed out for debug or release.
I haven't figured it out yet. The code appears to build properly.
Artix-7
FLASH: Micron MT25QL256
BTW xilisf v5.11 is broken for MT25QL256 parts, MT25QL128 works.
Chad
Grayed out is just a visual issue, otherwise the code works fine without any issue. This is a pure eclipse problem. Future upgrade of eclipse might solve this issue.
Raju
Is there any progress on this? It looks like if I do define in Project C/C++ options it shows active code under define as inactive.
Sorry, will answer to myself:
Preferences->Indexer->Use active build configuration
fixed it for me
