Voyager
Voyager
Coding a delay without effecting timeouts
Hey
I wanted to insert a delay function to allow sufficient time for my lwip DHCP configuration to bind so that i can print it successfully. I have a while loop as follows :
while (1) {
                            xemacif_input(netif);
                            if (netif->ip_addr.addr) {
                                xil_printf("DHCP IP stack added success\r\n");
                                *some delay function which does not effect timeouts*
   xil_printf("%d.%d.%d.%d\n\r", ip4_addr1(netif->ip_addr.addr),ip4_addr2(netif->ip_addr.addr),ip4_addr3(netif->ip_addr.addr), ip4_addr4(netif->ip_addr.addr));
                                 xil_printf("%d.%d.%d.%d\n\r", ip4_addr1(netif->netmask.addr),ip4_addr2(netif->netmask.addr),ip4_addr3(netif->netmask.addr), ip4_addr4(netif->netmask.addr));
                                 xil_printf("%d.%d.%d.%d\n\r", ip4_addr1(netif->gw.addr),ip4_addr2(netif->gw.addr),ip4_addr3(netif->gw.addr), ip4_addr4(netif->gw.addr));
                                break;
                            mscnt += DHCP_FINE_TIMER_MSECS;
                            if (mscnt >= DHCP_TIMEOUT_MS) {
                                xil_printf("ERROR: DHCP request timed out\r\n");
                                break;
When i try to run the program without the delay function the printf is still showing the initial values of the ip ( Which is 0.0.0.0  as it was initialised to this value at the start of my program )
But the DHCP is working perfectly. The DHCP is successfully configured and an IP address configuration is added to my netif . I even tested the echo server . But to find out the new dhcp address assigned i had to go to the network admin computer and check the dhcp server log manually to find out the assigned IP. I feel the printf is a bit premature so i want to insert a delay function to give it enough time to bind.
Can u suggest a suitable delay function which DOES NOT AFFECT THE TIME OUT PROCESS .  Or is there a better way of going about it?
Thanks a lot
Voyager
Voyager
Re: Coding a delay without effecting timeouts
Any one?
Here's what I used a while ago:
    // Wait for DHCP IP configuration
    while (1) {
        sleep(DHCP_FINE_TIMER_MSECS);
            xil_printf("DHCP request success\r\n");
            break;
        millisec_cnt += DHCP_FINE_TIMER_MSECS;
        if (millisec_cnt >= DHCP_TIMEOUT_MS) {
            return;
Voyager
Voyager
I tried the same thing. The DHCP configuration  is working but i am not able to print the new ip settings sent by the DHCP server to the xilinx board. Is using the following method to print the new ip settings wrong ?
The above code is just supposed to print the ip address. Simillarly for netmask i use :
and for the gateway :
Voyager
Voyager
I initially thought that its a delay problem , as in i was priniting the ip settings too early after the DHCP configuration. But now i think its something else entirely..
