Combining SDK C file and verilog to make a prom file
How do I combine my C file that I created in SDK with the Verilog files that I created in ISE as a .bit file or a .mcs file ? That is, when I burn the project into my fpga, let's say I have an LED blink routine that I wrote in C for a uBlaze instantiated in ISE, the leds must start blinking immediately rather than waiting for me to execute the C code (like I'm doing now) ?
Thank you
Scholar sampatd
Re: Combining SDK C file and verilog to make a prom file
Use data2mem command to combine the .bit file from ISE and the .elf application file to create a new .bit file
system.bit + application.elf -----> download.bit
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/data2mem.pdf
Next, use this (download.bit) .bit file with impact to create an mcs file.
https://www.digilentinc.com/Data/Documents/Tutorials/MCS%20File%20Creation%20with%20Xilinx%20ISE%20Tutorial.pdf
Scholar sampatd
Thank you, will try this and get back ! :D
hi,
you can refer to this procedure to integrate ISE design with a Embedded Sub-system.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/edk_ctt.pdf
If your C application is running from BRAM's inside the design, you need to run promgen to generate a MCS file that will use the updated bitstream with your software application. Once you program the PROM with MCS both the hardware design along with the processor C application will start executing
--hem
An easier technique that also works is the following:
If the processor is a submodule in ISE, one can add the elf file to the heirarchy. Once the file is added , a pop-up appears where one has to select an option which will link the elf file to the implementation (i dont remember the exact verbose ;)). Then, generate prog file will generate a bit file with the software+processor+logic info in it. This can be used to generate the mcs file.
Thank you !
