Compact Flash issue
Hello!
I'm trying to use Compact Flash for the first time. Firstly I created an Axi- based system with microblaze, SysAce Interface Controller (and all the other necessary IPs) in XPS 14.3. I exported my design in SDK and I succeded in reading the sectors of CF (just like the examples).
Unfortunately, I was not able to write sectors correctly and after many efforts, I decided to format the CF with Microsoft Windows format tool (selecting FAT for file system) (bad thing(?)) . Now I'm not able neither to read nor to write. The function XSysAce_Lock  always returns XST_DEVICE_BUSY.
Is this happening due to the format or is it something else?
I'm using SP605.
Thanks in advance!
Eleni
Re: Compact Flash issue
Hello Hem,
Thanks for your reply!
I re-formatted the CF with the "mkdosfs" formatting utility and everything works right now.
The answer was here: http://www.xilinx.com/support/answers/14456.htm.
After that I followed your suggestion to restore the contents of Compact Flash.
Thanks a lot!
Eleni.
Can you check if restoring the CF card contents do help?
http://www.xilinx.com/support/documentation/boards_and_kits/xtp061.pdf
--Hem
Hello Hem,
Thanks a lot!
Eleni.
