kavensun
Compile Assembly language project in SDK 2017.x
Hello everyone,
I have a Digilent Nexys4 DDR board based on the Artix-7 FPGA, and I want to compile the Assembly projects in the MicroBlaze. I have found some AR guide how to set in the old versions of Xilinx SDK, not apply for the latest SDK version.
In the latest SDK, when I create a new Application Project, the choice of programming languages only have C and C++. So my question is how can I create a new  Application Project based on Assembly language in the latest Xilinx SDK?
Thanks in advance!
Sikan
Tags (3)
ibaie
Hi @kavensun,
You can just create the C application project and then use the assembly language using .S files or .c files with inlining assembly.
Ibai
