awhill
Compiling static libraries in EDK 10.1
I've got a static library that I'd like to compile from source as part of my project compilation.  I was hoping it would be possible to run the custom makefile in the compilation sequence to create mylib.a, much like it does for libdriver.a and libxilkernel.a.  However, I wasn't able to find any options in libgen that would allow me to add this.  I already have a makefile and all the source, I just need to 'make' it.
I'm using Webpack and EDK 10.1.03 and a microblaze processor.
Thanks in advance,
Andrew
bassman59
Historian
Historian
Thanks in advance,
Andrew
I was looking into doing this today, but decided against it for unrelated reasons.
My guess is that you could open the EDK shell (you get a Cygwin shell) and use mb-gcc to compile the sources and then the standard Unix ar command to create the library. You should then put the library in some accessible location. In the EDK application Compiler Options dialog (right-click the Project: Name and choose "Set Compiler Options), the third tab is "Paths And Options" where you can entire a Library search path and libraries against which to link.
As I said, I haven't actually tried this; the stuff I wanted to included in my library had too many things specific to my current project that I needed to unroll first. Maybe next time!
-a
pavithra
Hi sorry instead  of repliying i m asking  doughts. i m new to EDK. how to use an  VHDL toplevel module(it contains many component modules) and how to add user libraries required by VHDL module when we creating custom ip.
thanks in advance
xiaofeip_dup
Hi Andrew,
You can define a user library just like you can have a driver for a custom peripheral.
You need to follow the EDK directory structure and provide the supporting files. In general, you need to put your library into sw_services directory and provide a MLD file.
More details can be found in psf_rm.pdf.
Hopefully this is what you are looking for.
Felix
