Configuration of Modelsim on EDK
I install the EDK 13.2 and Modelsim 10.0 on a Win 7 64bit platform. When I want to do the simulation, I find the only simulator we can select is the ISIM. The Others are not selectable.
How can I configure the Modelsim so that I can load it from the EDK?
Best Regards,
Wanjing
This is already answered.
http://forums.xilinx.com/t5/EDK-and-Platform-Studio/Modelsim-configuration-in-EDK/td-p/181380
Thnx
I'll move it to embedded forum as it involves XPS preference.
Thnx
