11-16-2008 07:35 PM
11-17-2008 06:14 PM
I guess I can't answer this question very well because it's not a one step job. Not easy for someone new.
First, you need to know about your VHDL codes. At least know its function and the top level port functions.
Second, you need to choose the bus for your IP - PLB46 or FSL? - Whether or not you need some advanced function of the bus, such as burst, etc.
Third, if your existing code can work well with the BUS template generated by the CIP wizard, you just need to connect their ports. But if not, you have to modify the code yourself.
11-17-2008 06:38 PM
XAPP967 can be a useful reference:
http://www.xilinx.com/support/documentation/application_notes/xapp967.pdf (Creating an OPB IPIF-based IP and Using it in EDK)
It was written for EDK 9.1i so it isn't the most current with the EDK 9.2i changes for the new PLB v4.6 infrastructure. But the concepts are similar.
You should also review the "Creating Your Own Intellectual Property (IP)"section of the "EDK Concepts, Tools, and Techniques" document. Available in your installation: %XILINX_EDK%\doc\usenglish\edk_ctt.pdf
Also available online for 10.1:
http://www.xilinx.com/support/documentation/sw_manuals/edk_ctt.pdf
bt
11-17-2008 06:58 PM
Good morning sir,
In the attachment, I have explained of the project system that I want to do. I had read
I have done VHDL codes is ISE 9.2 and it runs very well. Now I want to convert the codes into an IP.
1) Should I create the Core Template? Can I ignore it , and straight away import the VHDL codes into the EDK?
2) If I need to use Core Template, where can I insert my VHDL codes? Should I modify my VHDL codes by inserting them in the generated HDL folder codes? In HDL folder there are user_logic.vhd and LED.vhd. Which one should insert my codes?
Please explain in a simple way as I am new to FPGA world.
Thank you
11-17-2008 07:00 PM
11-18-2008 06:30 AM
hi,
in the guides that you read, you can realized that you should manipulate user_logic.vhd file to incorporate your funcionallity, now i think the solution for your problem is to instance your top VHDL as component inside user_logic.vhd, read help of EDK to know how you can import your VHDL files when you are using "Create Import Peripheral" wizard
good luck
P.D. i recommend that dont expect receive a step by step tutorial, it is hard that someone give to you something like that
12-04-2008 03:57 PM
I unable to receive hyperterminal input. Based on the coding below I can send , but can not receive the information . How can I rectify this problem?
#include "xparameters.h"
#include "xuartlite.h"
#define UART_BASEADDR XPAR_UARTLITE_0_BASEADDR
#define ESCAPE 0x1b
static void myprintf (char *s)
while (*s)
XUartLite_SendByte (UART_BASEADDR ,*s );
s++;
void echo()
char s;
do
s = XUartLite_RecvByte(UART_BASEADDR); // Does s receive the string?
if (s == '\r')
XUartLite_SendByte (UART_BASEADDR , '\n' ); //It should send back to Hyperterminal, but no output
XUartLite_SendByte (UART_BASEADDR , s ); //It should send back to Hyperterminal, but no output
} while (s != ESCAPE);
int main()
myprintf("Good morning \r\n"); //OK, hyperterminal will display "Good morning"
echo(); //NOT OK, hyperterminal will not display "Good morning"
return 0;
12-04-2008 03:59 PM
#define ESCAPE 0x1b
while (*s)
s++;
void echo()
char s;
do
if (s == '\r')
int main()
return 0;
