sirishy2k
Converting 8.2 to 13.1
I am trying to port ecOS on to ML403, I need the ML403 EDK Embedded MicroBlaze™ Reference Design for doing it but the problem is this refernce design is for version 8.2 I am using 13.1. Is there a tool to convert the old project to new one or is there a way to rebuild the whole project in the new tool.
--Sirish
dylan
Its likely best to start from scratch, as you'll need to switch from plb v3.4 to plbv4.6 bus standard and peripherals. I would create a design with BSB, since it supports ML403, and enable the same peripherals as the old design.
I hope this helps,
Dylan
