Custom Axi fifo
My question is very short:
I have the following HW setup for transfering data from hardware switches on my zedboard to DDR memory of one of Zynq processor.
Using the polling method from Xilinx sample codes, I am able to see the data on specified memory address(es) for the receive buffer.
/***************************** Include Files *********************************/
#include "xaxidma.h"
#include "xparameters.h"
#include "xdebug.h"
/******************** Constant Definitions **********************************/
 * Device hardware build related constants.
#define DMA_DEV_ID		XPAR_AXIDMA_0_DEVICE_ID
#ifdef XPAR_AXI_7SDDR_0_S_AXI_BASEADDR
#define DDR_BASE_ADDR		XPAR_AXI_7SDDR_0_S_AXI_BASEADDR
#elif defined (XPAR_MIG7SERIES_0_BASEADDR)
#define DDR_BASE_ADDR	XPAR_MIG7SERIES_0_BASEADDR
#elif defined (XPAR_MIG_0_BASEADDR)
#define DDR_BASE_ADDR	XPAR_MIG_0_BASEADDR
#elif defined (XPAR_PSU_DDR_0_S_AXI_BASEADDR)
#define DDR_BASE_ADDR	XPAR_PSU_DDR_0_S_AXI_BASEADDR
#endif
#ifndef DDR_BASE_ADDR
#warning CHECK FOR THE VALID DDR ADDRESS IN XPARAMETERS.H, \
		 DEFAULT SET TO 0x01000000
#define MEM_BASE_ADDR		0x01000000
#else
#define MEM_BASE_ADDR		(DDR_BASE_ADDR + 0x1000000)
#endif
#define TX_BUFFER_BASE		(MEM_BASE_ADDR + 0x00100000)
#define RX_BUFFER_BASE		(MEM_BASE_ADDR + 0x00300000)
#define RX_BUFFER_HIGH		(MEM_BASE_ADDR + 0x004FFFFF)
#define MAX_PKT_LEN		0x20
/************************** Function Prototypes ******************************/
#if (!defined(DEBUG))
extern void xil_printf(const char *format, ...);
#endif
int XAxiDma_SimplePollExample(u16 DeviceId);
static int CheckData(void);
/************************** Variable Definitions *****************************/
 * Device instance definitions
XAxiDma AxiDma;
int main()
	int Status;
	xil_printf("\r\n--- Entering main() --- \r\n");
	/* Run the poll example for simple transfer */
	Status = XAxiDma_SimplePollExample(DMA_DEV_ID);
	if (Status != XST_SUCCESS) {
		xil_printf("XAxiDma_SimplePoll Example Failed\r\n");
		return XST_FAILURE;
	xil_printf("Successfully ran XAxiDma_SimplePoll Example\r\n");
	xil_printf("--- Exiting main() --- \r\n");
	return XST_SUCCESS;
	XAxiDma_Config *CfgPtr;
	int Status;
	int Index;
	u8 *RxBufferPtr;
	u8 Value;
	RxBufferPtr = (u8 *)RX_BUFFER_BASE;
	/* Disable interrupts, we use polling mode */
	XAxiDma_IntrDisable(&AxiDma, XAXIDMA_IRQ_ALL_MASK,
						XAXIDMA_DEVICE_TO_DMA);
						XAXIDMA_DMA_TO_DEVICE);
	u8 *RxPacket;
	RxPacket = (u8 *) RX_BUFFER_BASE;
	while (1)
		/* Initialize the XAxiDma device. */
		CfgPtr = XAxiDma_LookupConfig(DeviceId);
		if (!CfgPtr) {
			xil_printf("No config found for %d\r\n", DeviceId);
			return XST_FAILURE;
		Status = XAxiDma_CfgInitialize(&AxiDma, CfgPtr);
			xil_printf("Initialization failed %d\r\n", Status);
			return XST_FAILURE;
		// simple transfer
		Status = XAxiDma_SimpleTransfer(&AxiDma,(UINTPTR) RxBufferPtr,
				MAX_PKT_LEN, XAXIDMA_DEVICE_TO_DMA);
			return XST_FAILURE;
		// wait for receive
		while (XAxiDma_Busy(&AxiDma, XAXIDMA_DEVICE_TO_DMA)) {
				/* Wait */
		xil_printf("%x \n\r", (unsigned int)RxPacket[0]);
	return XST_SUCCESS;
I expected to see new values on receive memory addresses once I changed the switches, but for that to happen I have to re-run the program on the processor. I can't find the problem because I have a very simple design. I think maybe peripheral_aresetn pin is not re-asserted and my custom axi block outputs only once.
Any help is very appreciated.
Tags (4)
