Custom IP driver not present on BSP
Hi all,
I'm having problems trying to use Custom IP drivers on SDK.
Originally, I have a project with a lot of blocks. When generating HDF file and then the BSP everything was OK: I had all drivers, Xilinx blocks and Custom IPs drivers. So far, so good.
Then, I have to create a very similar project, so I used the autogenerated TCL script to recreate the block design. I replaced some blocks (Custom IPs) and when I try to generate the BSP some custom IP drivers were set to GENERIC. But the strange thing is that the Custom IP that I added (not the ones created by the script TCL) have their drivers.
 From the HDF file I can check that all blocks are present
But on the mss file the drivers are missing:
As information, the datademodv2..... block is the IP that I added last => the driver is present. All the others Generics are the Custom IP blocks created by the TCL script.
I found a workaround adding in SDK repositories the path to each driver but I would like to know why the drivers handoff it is not done properly.
Thanks for you help
Regards!
Re: Custom IP driver not present on BSP
Check your .vdi file under your impl_1 directory.  After the block where it sources all the .tcl files, do you have a message like this:
zip_exception: Failed to open zip archive C:/Sandbox/bar/test_vivado_2018.2/foo/foo.runs/impl_1/foo.hwdef. This may indicate that the file is corrupt, that there is insufficient free disk space available to uncompress it, or that you do not have permission to create files
and
zip_exception: zip archive C:/Sandbox/bar/test_vivado_2018.2/foo/foo.runs/impl_1/foo.hwdef is already open for writing
a bunch of times?  And are you on a Windows platform?
If so, I'm seeing the same thing.  I had opened a webcase, unfortunately I could not share my entire design with the support people and could not successfully recreate it with a testcase.
If it helps, it does not occur on Linux, only windows.  I have also ruled out interactions with virus scanners and other endpoint security software.
Please!!! Anybody can help me? Thanks!
and
Hi @kenryan2
Thanks for your answer. In fact I have the errors that you mention! I'm using Windows 7.
I will continue to use the workaround (point manually using repositories). Let me know if you have any update with the Webcase.
Best regards
