andrew57jm
Custom IP interrupts sensitivity
With Vivado 15.2 I'm packaging some custom IP that has an interrupt output that will go to the AXI interrupt controller and a microblaze processor. I want the interrupt to be edge sensitive. So when I package the IP I go to "Ports and Interfaces" and edit the interface that has my interrupt and give it a parameter "SENSITIVITY" with a value of "EDGE_RISING". But when I put that IP on my main project's block design and double click on the interrupt pin it says "LEVEL_RISING". And as a result the interrupt controller then makes the wrong decision about the interrupt sensitivity and things don't work. How do I package my IP to get the correct interrupt sensitivity?
smarell
Community Manager
Community Manager
Can you overwrite the sensitivity parameter via TCL?
pvenugo
Refer to https://www.xilinx.com/support/answers/60837.html
Praveen
