DDR3 Memory model
I am using VC707 Board, which has a Micron DDR3 SDRAM.  This is the DDR3 part that it looks like is there on this board -
I want to simulate my design.  Where can I find the verilog simulation model for this part of the memory?
I couldn't find it on Micron website for this part.
Micron DDR3 Specs :
   - Clock Period: 1250 ps
   – Type: SODIMMs
   – Part: MT8JTF12864HZ1G6
Re: DDR3 Memory model
There is a micron memory model IP that you can add to your Block design in IPI and test here:
Note, there is also simulation UART, and Clock and RESET too:
You can add this to the repo:
