DDR3 SDRAM test failed
I'm trying to test DDR3 using memory test application. But every time only so many things are displayed.
--Starting Memory Test Application--
NOTE: ThisApplication runs with D-Cache disaBled.As a result, cacheline requests will not be generated
Testing memory region: mcb_ddr3
    Memory Controller: axi_s6_ddrx
         Base Address: 0xc0000000
Can anyone suggest what can be wrong because of which this is happening?
Re: DDR3 SDRAM test failed
Did you enable caches?
Could you disable it and try to run the application?
Did disbaling caches work?
Praveen
hi,
this seems to be a spartan-6 memory controller block.
  • can you confirm if you have completed configuring the controller properly?
  • Is this a custom board or a development board?
  • Is this with MPMC or AXI interface IP?
--hs
No disabling cache will not give solution to that problem but it will give some error
Yes it is Spartan 6 controller.
* Yes I verified and controller is configured properly.
* It's a development board.
* It's a AXI based interface.
Visitor miguelcosta
The same is happening to me with a Kintex 7 KC705 board.
Has anyone found a solution?
