nliang
DEVICE ID generated in xparamaters.h is all 0
when i create an application example and library have been set up. then i came back to xparameters.h, and found all device id is 0. i run the self exam, and it kept looping, which looks like it cannot run into the register address. all i can guess is that function cannot find the right pointer based on all the same device id.
so how can i find device id? then i can modify it by myself.
stephenm
Can you try just setting this to 1 (assuming this is correct), and see if app works. If this still fails, then issue is in your app
