05-21-2008 06:38 AM
I am trying to figure out why my dma does not work. In the process of debug I dumped the memory where I expected the DMA to be assigned to.
I assigned the PLB_CENTRAL_DMA to be at address 0x40000000 and I connected the SPLB bus to the mb_plb bus. Then I started running my program and
created a break point in the middle of the program after some of the DMA commands had been executed. I dumped the memory at the
0x40000000 range and though this area the memory is reading all zeros.
Can anyone explain this?
Thank You,
Gary Olson
05-21-2008 07:46 AM
Here is the MHS
# Created by Base System Builder Wizard for Xilinx EDK 10.1 Build EDK_K.15
# Fri May 16 10:15:24 2008
# Target Board: Xilinx Virtex 5 ML505 Evaluation Platform Rev 1
# Family: virtex5
# Device: xc5vlx50t
# Package: ff1136
# Speed Grade: -1
# Processor: microblaze_0
# System clock frequency: 125.00 MHz
# On Chip Memory : 16 KB
# Total Off Chip Memory : 257 MB
# - SRAM = 1 MB
# - DDR2_SDRAM = 256 MB
PARAMETER VERSION = 2.1.0
PORT fpga_0_RS232_Uart_1_RX_pin = fpga_0_RS232_Uart_1_RX, DIR = I
PORT fpga_0_RS232_Uart_1_TX_pin = fpga_0_RS232_Uart_1_TX, DIR = O
PORT fpga_0_LEDs_8Bit_GPIO_IO_pin = fpga_0_LEDs_8Bit_GPIO_IO, DIR = IO, VEC = [0:7]
PORT fpga_0_SRAM_Mem_A_pin = fpga_0_SRAM_Mem_A, DIR = O, VEC = [7:30]
PORT fpga_0_SRAM_Mem_DQ_pin = fpga_0_SRAM_Mem_DQ, DIR = IO, VEC = [0:31]
PORT fpga_0_SRAM_Mem_BEN_pin = fpga_0_SRAM_Mem_BEN, DIR = O, VEC = [0:3]
PORT fpga_0_SRAM_Mem_OEN_pin = fpga_0_SRAM_Mem_OEN, DIR = O
PORT fpga_0_SRAM_Mem_CEN_pin = fpga_0_SRAM_Mem_CEN, DIR = O
PORT fpga_0_SRAM_Mem_ADV_LDN_pin = fpga_0_SRAM_Mem_ADV_LDN, DIR = O
PORT fpga_0_SRAM_Mem_WEN_pin = fpga_0_SRAM_Mem_WEN, DIR = O
PORT fpga_0_DDR2_SDRAM_DDR2_ODT_pin = fpga_0_DDR2_SDRAM_DDR2_ODT, DIR = O, VEC = [1:0]
PORT fpga_0_DDR2_SDRAM_DDR2_Addr_pin = fpga_0_DDR2_SDRAM_DDR2_Addr, DIR = O, VEC = [12:0]
PORT fpga_0_DDR2_SDRAM_DDR2_BankAddr_pin = fpga_0_DDR2_SDRAM_DDR2_BankAddr, DIR = O, VEC = [1:0]
PORT fpga_0_DDR2_SDRAM_DDR2_CAS_n_pin = fpga_0_DDR2_SDRAM_DDR2_CAS_n, DIR = O
PORT fpga_0_DDR2_SDRAM_DDR2_CE_pin = fpga_0_DDR2_SDRAM_DDR2_CE, DIR = O, VEC = [1:0]
PORT fpga_0_DDR2_SDRAM_DDR2_CS_n_pin = fpga_0_DDR2_SDRAM_DDR2_CS_n, DIR = O, VEC = [1:0]
PORT fpga_0_DDR2_SDRAM_DDR2_RAS_n_pin = fpga_0_DDR2_SDRAM_DDR2_RAS_n, DIR = O
PORT fpga_0_DDR2_SDRAM_DDR2_WE_n_pin = fpga_0_DDR2_SDRAM_DDR2_WE_n, DIR = O
PORT fpga_0_DDR2_SDRAM_DDR2_Clk_pin = fpga_0_DDR2_SDRAM_DDR2_Clk, DIR = O, VEC = [1:0]
PORT fpga_0_DDR2_SDRAM_DDR2_Clk_n_pin = fpga_0_DDR2_SDRAM_DDR2_Clk_n, DIR = O, VEC = [1:0]
PORT fpga_0_DDR2_SDRAM_DDR2_DM_pin = fpga_0_DDR2_SDRAM_DDR2_DM, DIR = O, VEC = [7:0]
PORT fpga_0_DDR2_SDRAM_DDR2_DQS = fpga_0_DDR2_SDRAM_DDR2_DQS, DIR = IO, VEC = [7:0]
PORT fpga_0_DDR2_SDRAM_DDR2_DQS_n = fpga_0_DDR2_SDRAM_DDR2_DQS_n, DIR = IO, VEC = [7:0]
PORT fpga_0_DDR2_SDRAM_DDR2_DQ = fpga_0_DDR2_SDRAM_DDR2_DQ, DIR = IO, VEC = [63:0]
PORT fpga_0_SRAM_CLK = ZBT_CLK_OUT_s, DIR = O
PORT fpga_0_SRAM_CLK_FB = ZBT_CLK_FB_s, DIR = I, SIGIS = CLK, CLK_FREQ = 125000000
PORT sys_clk_pin = dcm_clk_s, DIR = I, SIGIS = CLK, CLK_FREQ = 100000000
PORT sys_rst_pin = sys_rst_s, DIR = I, RST_POLARITY = 0, SIGIS = RST
BEGIN microblaze
PARAMETER INSTANCE = microblaze_0
PARAMETER C_INTERCONNECT = 1
PARAMETER HW_VER = 7.10.a
PARAMETER C_DEBUG_ENABLED = 1
BUS_INTERFACE DLMB = dlmb
BUS_INTERFACE ILMB = ilmb
BUS_INTERFACE DPLB = mb_plb
BUS_INTERFACE IPLB = mb_plb
BUS_INTERFACE DEBUG = microblaze_0_dbg
PORT MB_RESET = mb_reset
PORT INTERRUPT = xps_intc_0_Irq
END
BEGIN plb_v46
PARAMETER INSTANCE = mb_plb
PARAMETER HW_VER = 1.02.a
PORT PLB_Clk = sys_clk_s
PORT SYS_Rst = sys_bus_reset
END
BEGIN lmb_v10
PARAMETER INSTANCE = ilmb
PARAMETER HW_VER = 1.00.a
PORT LMB_Clk = sys_clk_s
END
BEGIN lmb_v10
PARAMETER INSTANCE = dlmb
END
BEGIN lmb_bram_if_cntlr
PARAMETER INSTANCE = dlmb_cntlr
PARAMETER HW_VER = 2.10.a
PARAMETER C_BASEADDR = 0x00000000
PARAMETER C_HIGHADDR = 0x00003fff
BUS_INTERFACE SLMB = dlmb
BUS_INTERFACE BRAM_PORT = dlmb_port
END
PARAMETER INSTANCE = ilmb_cntlr
BUS_INTERFACE SLMB = ilmb
BUS_INTERFACE BRAM_PORT = ilmb_port
END
BEGIN bram_block
PARAMETER INSTANCE = lmb_bram
BUS_INTERFACE PORTA = ilmb_port
BUS_INTERFACE PORTB = dlmb_port
END
BEGIN xps_uartlite
PARAMETER INSTANCE = RS232_Uart_1
PARAMETER C_BAUDRATE = 9600
PARAMETER C_DATA_BITS = 8
PARAMETER C_ODD_PARITY = 0
PARAMETER C_USE_PARITY = 0
PARAMETER C_SPLB_CLK_FREQ_HZ = 125000000
PARAMETER C_BASEADDR = 0x84000000
PARAMETER C_HIGHADDR = 0x8400ffff
BUS_INTERFACE SPLB = mb_plb
PORT RX = fpga_0_RS232_Uart_1_RX
PORT TX = fpga_0_RS232_Uart_1_TX
END
BEGIN xps_gpio
PARAMETER INSTANCE = LEDs_8Bit
PARAMETER C_GPIO_WIDTH = 8
PARAMETER C_IS_DUAL = 0
PARAMETER C_IS_BIDIR = 1
PARAMETER C_ALL_INPUTS = 0
PARAMETER C_BASEADDR = 0x81400000
PARAMETER C_HIGHADDR = 0x8140ffff
PORT GPIO_IO = fpga_0_LEDs_8Bit_GPIO_IO
END
BEGIN xps_mch_emc
PARAMETER INSTANCE = SRAM
PARAMETER C_MCH_PLB_CLK_PERIOD_PS = 8000
PARAMETER C_NUM_BANKS_MEM = 1
PARAMETER C_MAX_MEM_WIDTH = 32
PARAMETER C_MEM0_WIDTH = 32
PARAMETER C_INCLUDE_DATAWIDTH_MATCHING_0 = 0
PARAMETER C_SYNCH_MEM_0 = 1
PARAMETER C_TCEDV_PS_MEM_0 = 0
PARAMETER C_TWC_PS_MEM_0 = 0
PARAMETER C_TAVDV_PS_MEM_0 = 0
PARAMETER C_TWP_PS_MEM_0 = 0
PARAMETER C_THZCE_PS_MEM_0 = 0
PARAMETER C_THZOE_PS_MEM_0 = 0
PARAMETER C_TLZWE_PS_MEM_0 = 0
PARAMETER C_MEM0_BASEADDR = 0x8a300000
PARAMETER C_MEM0_HIGHADDR = 0x8a3fffff
PORT Mem_A = fpga_0_SRAM_Mem_A_split
PORT Mem_BEN = fpga_0_SRAM_Mem_BEN
PORT Mem_WEN = fpga_0_SRAM_Mem_WEN
PORT Mem_OEN = fpga_0_SRAM_Mem_OEN
PORT Mem_DQ = fpga_0_SRAM_Mem_DQ
PORT Mem_CEN = fpga_0_SRAM_Mem_CEN
PORT Mem_ADV_LDN = fpga_0_SRAM_Mem_ADV_LDN
END
BEGIN mpmc
PARAMETER INSTANCE = DDR2_SDRAM
PARAMETER HW_VER = 4.00.a
PARAMETER C_NUM_PORTS = 1
PARAMETER C_MEM_PARTNO = mt4htf3264h-53e
PARAMETER C_NUM_IDELAYCTRL = 3
PARAMETER C_IDELAYCTRL_LOC = IDELAYCTRL_X0Y5-IDELAYCTRL_X0Y1-IDELAYCTRL_X0Y0
PARAMETER C_MEM_DQS_IO_COL = 0b00_0000_0000_0000_0000
PARAMETER C_MEM_DQ_IO_MS = 0b00000000_01110101_00111101_00001111_00011110_00101110_11000011_11000001_10111100
PARAMETER C_DDR2_DQSN_ENABLE = 1
PARAMETER C_MEM_CE_WIDTH = 2
PARAMETER C_MEM_CS_N_WIDTH = 2
PARAMETER C_MEM_CLK_WIDTH = 2
PARAMETER C_MEM_ODT_WIDTH = 2
PARAMETER C_MEM_ODT_TYPE = 1
PARAMETER C_PIM0_BASETYPE = 2
PARAMETER C_MPMC_CLK0_PERIOD_PS = 8000
PARAMETER C_MPMC_BASEADDR = 0x90000000
PARAMETER C_MPMC_HIGHADDR = 0x9fffffff
BUS_INTERFACE SPLB0 = mb_plb
PORT DDR2_ODT = fpga_0_DDR2_SDRAM_DDR2_ODT
PORT DDR2_Addr = fpga_0_DDR2_SDRAM_DDR2_Addr
PORT DDR2_BankAddr = fpga_0_DDR2_SDRAM_DDR2_BankAddr
PORT DDR2_CAS_n = fpga_0_DDR2_SDRAM_DDR2_CAS_n
PORT DDR2_CE = fpga_0_DDR2_SDRAM_DDR2_CE
PORT DDR2_CS_n = fpga_0_DDR2_SDRAM_DDR2_CS_n
PORT DDR2_RAS_n = fpga_0_DDR2_SDRAM_DDR2_RAS_n
PORT DDR2_WE_n = fpga_0_DDR2_SDRAM_DDR2_WE_n
PORT DDR2_Clk = fpga_0_DDR2_SDRAM_DDR2_Clk
PORT DDR2_Clk_n = fpga_0_DDR2_SDRAM_DDR2_Clk_n
PORT DDR2_DM = fpga_0_DDR2_SDRAM_DDR2_DM
PORT DDR2_DQS = fpga_0_DDR2_SDRAM_DDR2_DQS
PORT DDR2_DQS_n = fpga_0_DDR2_SDRAM_DDR2_DQS_n
PORT DDR2_DQ = fpga_0_DDR2_SDRAM_DDR2_DQ
PORT MPMC_Clk0 = sys_clk_s
PORT MPMC_Clk90 = DDR2_SDRAM_mpmc_clk_90_s
PORT MPMC_Clk_200MHz = clk_200mhz_s
PORT MPMC_Clk0_DIV2 = DDR2_SDRAM_MPMC_Clk_Div2
PORT MPMC_Rst = sys_periph_reset
END
BEGIN util_bus_split
PARAMETER INSTANCE = SRAM_util_bus_split_2
PARAMETER C_SIZE_IN = 32
PARAMETER C_LEFT_POS = 7
PARAMETER C_SPLIT = 31
PORT Sig = fpga_0_SRAM_Mem_A_split
PORT Out1 = fpga_0_SRAM_Mem_A
END
BEGIN clock_generator
PARAMETER INSTANCE = clock_generator_0
PARAMETER HW_VER = 2.00.a
PARAMETER C_EXT_RESET_HIGH = 1
PARAMETER C_CLKIN_FREQ = 100000000
PARAMETER C_CLKOUT0_FREQ = 125000000
PARAMETER C_CLKOUT0_BUF = TRUE
PARAMETER C_CLKOUT0_PHASE = 0
PARAMETER C_CLKOUT0_GROUP = PLL0
PARAMETER C_CLKOUT1_FREQ = 125000000
PARAMETER C_CLKOUT1_BUF = TRUE
PARAMETER C_CLKOUT1_PHASE = 90
PARAMETER C_CLKOUT1_GROUP = PLL0
PARAMETER C_CLKOUT2_FREQ = 200000000
PARAMETER C_CLKOUT2_BUF = TRUE
PARAMETER C_CLKOUT2_PHASE = 0
PARAMETER C_CLKOUT2_GROUP = NONE
PARAMETER C_CLKOUT3_FREQ = 62500000
PARAMETER C_CLKOUT3_BUF = TRUE
PARAMETER C_CLKOUT3_PHASE = 0
PARAMETER C_CLKOUT3_GROUP = NONE
PARAMETER C_CLKFBIN_FREQ = 125000000
PARAMETER C_CLKFBOUT_FREQ = 125000000
PARAMETER C_CLKFBOUT_BUF = TRUE
PORT CLKOUT0 = sys_clk_s
PORT CLKOUT1 = DDR2_SDRAM_mpmc_clk_90_s
PORT CLKOUT2 = clk_200mhz_s
PORT CLKOUT3 = DDR2_SDRAM_MPMC_Clk_Div2
PORT CLKIN = dcm_clk_s
PORT LOCKED = Dcm_all_locked
PORT RST = net_gnd
PORT CLKFBIN = ZBT_CLK_FB_s
PORT CLKFBOUT = ZBT_CLK_OUT_s
END
BEGIN mdm
PARAMETER INSTANCE = debug_module
PARAMETER HW_VER = 1.00.b
PARAMETER C_MB_DBG_PORTS = 1
PARAMETER C_USE_UART = 1
PARAMETER C_UART_WIDTH = 8
PARAMETER C_BASEADDR = 0x84400000
PARAMETER C_HIGHADDR = 0x8440ffff
BUS_INTERFACE MBDEBUG_0 = microblaze_0_dbg
PORT Debug_SYS_Rst = Debug_SYS_Rst
END
BEGIN proc_sys_reset
PARAMETER INSTANCE = proc_sys_reset_0
PARAMETER C_EXT_RESET_HIGH = 0
PORT Slowest_sync_clk = sys_clk_s
PORT Dcm_locked = Dcm_all_locked
PORT Ext_Reset_In = sys_rst_s
PORT MB_Reset = mb_reset
PORT Bus_Struct_Reset = sys_bus_reset
PORT MB_Debug_Sys_Rst = Debug_SYS_Rst
PORT Peripheral_Reset = sys_periph_reset
END
BEGIN xps_central_dma
PARAMETER INSTANCE = xps_central_dma_0
PARAMETER C_BASEADDR = 0x40000000
PARAMETER C_HIGHADDR = 0x4000FFFF
PORT IP2INTC_Irpt = xps_central_dma_0_IP2INTC_Irpt
END
BEGIN ipif_may18
PARAMETER INSTANCE = ipif_may18_0
PARAMETER HW_VER = 1.01.a
PARAMETER C_BASEADDR = 0x60000000
PARAMETER C_HIGHADDR = 0x6000ffff
PORT IP2INTC_Irpt = ipif_may18_0_IP2INTC_Irpt
END
BEGIN xps_intc
PARAMETER INSTANCE = xps_intc_0
PARAMETER C_BASEADDR = 0x20000000
PARAMETER C_HIGHADDR = 0x2000ffff
PORT Irq = xps_intc_0_Irq
PORT Intr = xps_central_dma_0_IP2INTC_Irpt&ipif_may18_0_IP2INTC_Irpt
END
05-21-2008 10:36 AM
I tried hooking DMA component at first to SPLB port. So now I tried hooking up to MPLB port. But the Device code does not appear underneath Microblaze_0 libsrc directory.
My third attempt is to see what will happen if I hook up the SPLB and MPLB to the mb_plb.
This time at least the device code is in the directory. I also noticed XAPP999 hooked the DMA component that way. I am in the process of synthesis now.
05-21-2008 11:17 AM
