Debug Download failed to SP601 board
Accepted Solution Solved
Accepted Solution
I´m working with EDK 12.1 and a Spartan SP601 board. I worked for a while with small c-Projects with SDK and debugging via the on-board USB-JTAG. With another (bigger) project I can not download the elf-file to the board.
I get the following message (if I try it the first time after downloading the bitstream (this works always):
(mb-gdb console)
.gdbinit: No such file or directory.
Ignoring packet error, continuing...
(after that in a message box)
Unexpected error while launching program: Error downloading program to target: Target is not responding (timed out)
Trying it more times I get the message:
(mb-gdb console)
Unexpected error while launching program: target selection failed
I already tried a .gdbinit file with the following entries:
set download-write-size 4096
set remote memory-write-packet-size 4096
set remote memory-write-packet-size fixed
set remote memory-read-packet-size 4096
set remote memory-read-packet-size fixed
Got the same result...
Any ideas?
Thomas
Re: Debug Download failed to SP601 board
Hi Thomas,
It looks like your error is related to what is found in answer record 35996 - http://www.xilinx.com/support/answers/35996.htm
All Replies
Hi Thomas,
problem solved.
Thx
Thomas
I have the error message:
I'm using XPS 12.2, so the error should be solved.
Does anyone know a workaround?
Hello!
I had the same problem. To resolve it I did the following:
* Get the IP-adress of my machine, e.g. 192.168.101.103
* Right click on the .elf file that you want to debug and select Debug As -> Debug configurations
* Select the "Remote Debug" tab and check the "Connect to gdbserver on a different machine" checkbox
* Enter the IP Address that you determined above
* Press Apply and Debug
Unfortunately these steps have to be repeated every time your IP Address changes, e.g. after a reboot.
Any easier metho would be appreciated. Any suggestions?
You can use the hostname instead of the IP address.
