Newbie arunkm
Debug problem in SDK 14.7
Hello Everyone,
 I'm SDK 14.7 to develop one of our application. we have migrated from SDK13.4.
Now, i'm trying to debug the application developed in 13.4 in 14.7.
I have imported the older design in to the workspace and built it. later downloaded .bit, .bmm, and .elf files on to FPGA successfully. I've selected Debug as option "local c/C++ Apllication"
 when i try to debug .elf, i'm getting following error.
The screen shot is attached
Kindly let me know...are there any setting that are missing?
where am i doing wrong?
Thank you,
Ravikumar
Re: Debug problem in SDK 14.7
Launching on Hardware is a Xilinx Specific debug, which will use the powerpc-eabi-gdb or the mb-gdb etc. This option will call the correct debug with the correct options on the correct Xilinx hardware.
The Local C/C++ Application is a standard button in the Eclipse toolchain, which will call the machines local gdb which can be set up under Project -> Debug configurations. This would be for third party devices/debugging.
This would explain why the gdb version is being found as incorrect.
Achutha
Did the information shared in my last post helped you to understand the issue?
Achutha
