c.mcclenaghan
Debugging Linux Applications using over JTAG
Hi all
I need some help connecting my debugger a Zynq board over JTAG.
Windows 7/CentOS 7
SDK v2015.2
Petalinux v2015.2
I have created an Hello World (Linux) application and can debug it on my Zedboard over ethernet by creating a Linux TCF Agent connection with my custom IP address. (SDK debugging guide etc...)
However, using a Digilent USB-JTAG cable (JTAG-HS3), running the hw_server with
hw_server -s tcp:127.0.0.1:1534
and creating another Linux TCF Agent connection pointing to 127.0.0.1:1534, the debugger won't start. It shows the following error: "Target does not provide Processes service"
I can't find much information on this error anywhere. This occurs on a Zedboard with custom Linux build and on a custom Zynq board (without ethernet).
If I don't run the hw server, I get a "connection refused" error so that's understandable. My JTAG cable allows standalone debugging so I don't suspect that side.
Presumably, there is something in the Petalinux kernel configuration I has missed?
I need to get JTAG debugging working on our custom board so any help would be appreciated.
Chris
PS. I've just tracked down a Xilinx Platform Cable USB II and this shows the same thing.
c.mcclenaghan
c.mcclenaghan
