Observer josephchau77
Documentation UG1186 OpenAMP example coding
Hello all
I try to followed example from doc UG1186 to implement OpenAMP
running the Matrix multiplication test.  Does any one know where
can I get implementation/coding for this example test.
best regards
joe chau
Re: Documentation UG1186 OpenAMP example coding
Thanks you
I found it
best regards
joe chau
@josephchau77
Please check this https://github.com/Xilinx/open-amp/blob/xilinx-v2018.2/apps/matrix_multiply/matrix_multiply.c
Best Regards,
Nutan
Please do not forget to reply, kudo and accept as a solution
Best Regards,
Nutan
Hello Nutang
Thanks for your help, this is coding for RPU (slave/remote processor side)
where can I found APU coding (master).
I also try to run a simple ECHO test, where do I find complete coding
for this test (including APU/RPU side)
Best Regards
joe chau
Thanks you
I found it
best regards
joe chau
