Double fifo size of uart lite
I'm relatively new to using XPS, and have been tinkering around with some serial communication with the uart lite on a spartan 3an development board.  I am curious if it is possible to modify the fifo size of the send and recieve buffers though.  A 32 byte buffer would be much more suited for my purposes in the long run.  Does anyone know if this is feasible?
Thankyou,
wgibb
Re: Double fifo size of uart lite
It is not possible as far as changing a simple parameter in the IP configuration to increase the FIFO size.
The FIFO size in this core is fixed at 16 bytes.
However, this core is available in plaintext in the EDK cores directory (e.g. %XILINX_EDK%\hw\XilinxProcessorIPLib\pcores\xps_uartlite_v1_00_a\hdl\vhdl)
It is theoretically possible to copy this core to your local pcores, change the names, and modify the implementation to use a larger FIFO.
This is likely beyond the scope of what most people would want to do or support. But it is possible.
The size 16 deep comes from the SRL16. You would have to change the default FIFO implementation (e.g. cascade multiple SRL16 FIFOs or switch to a BRAM FIFO).
Cheers,
bt
Message Edited by timpe on 03-07-2008 03:29 AM
Is it possible if I just change the C_DEPTH within the within uartlite_tx/rx.vhdl file shouldn't it work I notice the fifo is setup as generic.
I'mt using proc_common_v3_00_a.srl_fifo_f for the fido and the uartlite is version 1.02a
