dkartis2
Download elf file to Microblaze from Android phone
Hi, I have a microblaze based Artix 7 design with code that I'm able to run from the Xilinx SDK. Is it possible to download or run the elf file from the phone to the board through USB? I want the phone to behave as the PC. Thanks for any help you can provide
Anonymous
Not applicable
You can set up the "phone" as a storage device. I use inverted comma's as the USB would just see the memory on your phone.
So, you would need to add the AXI USB IP to your system. There is example driver code below to set up the storage device:
C:\Xilinx\SDK\2015.2\data\embeddedsw\XilinxProcessorIPLib\drivers\usb_v5_0\examples
You can use them. You would then just copy the elf into your memory on your phone, then use the USB driver to copy this from the memory into local memory. then you can reboot the microblaze.
boot_app = (int (*) (void)) XPAR_MICROBLAZE_0_BASE_VECTORS;
boot_app();
Anonymous
Not applicable
boot_app();
dkartis2
That is amazing, thank you so much. You just opened the door for me, thanks again!
