Observer makarau1
Dual core Microblaze XSDK Run/Debug
Dear Experts,
I have 2 core Microblaze HW with one MDM for the two processors. The MDM has the following config:
The targets are as follows:
xsct% targets
1 xcku040
     2 MicroBlaze Debug Module at USER2
       3* MicroBlaze #0 (Running)
       4 MicroBlaze #1 (Running)
5 04900220
xsct%
With a bitstream included the mb1_test.elf (Microblaze 0) and mb2_test.elf (Microblaze 1) the software runs smoothly.
My problem is that I cannot run the software in the Run or Debug in the XSDK. For the ELFs I have the following config:
The ELFs are build with the Debug configuration.
Programming the FPGA with a bitstream (no ELFs included) and then running the Debug the following errors rise in the SDK log:
15:38:03 INFO   : Connected to target on host '127.0.0.1' and port '3121'.
15:38:04 INFO   : 'targets -set -filter {jtag_cable_name =~ "Digilent JTAG-SMT2 210251A4627A" && level==0} -index 0' command is executed.
15:38:13 INFO   : FPGA configured successfully with bitstream "C:/xprj/dual_mb_00/dual_mb.sdk/dual_mb_00_top_hw_platform_0/dual_mb_00_top.bit"
15:38:18 INFO   : CPU Number not found for processor design_mb_1_wrapper_inst_design_mb_1_i_microblaze_0, defaulting to 0
15:38:18 INFO   : CPU Number not found for processor design_mb_2_wrapper_inst_design_mb_2_i_microblaze_0, defaulting to 0
15:38:18 INFO   : 'targets -set -filter {jtag_cable_name =~ "Digilent JTAG-SMT2 210251A4627A" && level==0} -index 0' command is executed.
15:38:18 INFO   : 'fpga -state' command is executed.
15:38:18 INFO   : Connected to target on host '127.0.0.1' and port '3121'.
15:38:18 INFO   : Bscan info not found for microblaze design_mb_1_wrapper_inst_design_mb_1_i_microblaze_0, defaulting to 2
15:38:18 INFO   : Bscan info not found for microblaze design_mb_2_wrapper_inst_design_mb_2_i_microblaze_0, defaulting to 2
15:38:18 INFO   : Jtag cable 'Digilent JTAG-SMT2 210251A4627A' is selected.
15:38:18 INFO   : 'jtag frequency' command is executed.
15:38:18 INFO   : Context for processor 'design_mb_1_wrapper_inst_design_mb_1_i_microblaze_0' is selected.
15:38:19 INFO   : The application 'C:/xprj/dual_mb_00/dual_mb.sdk/mb1_test/Debug/mb1_test.elf' is downloaded to processor 'design_mb_1_wrapper_inst_design_mb_1_i_microblaze_0'.
15:38:19 INFO   : Context for processor 'design_mb_2_wrapper_inst_design_mb_2_i_microblaze_0' is selected.
15:38:20 INFO   : The application 'C:/xprj/dual_mb_00/dual_mb.sdk/mb2_test/Debug/mb2_test.elf' is downloaded to processor 'design_mb_2_wrapper_inst_design_mb_2_i_microblaze_0'.
15:38:20 INFO   : ----------------XSDB Script----------------
connect -url tcp:127.0.0.1:3121
targets -set -nocase -filter {name =~ "microblaze*#0" && bscan=="USER2" && jtag_cable_name =~ "Digilent JTAG-SMT2 210251A4627A"} -index 0
dow C:/xprj/dual_mb_00/dual_mb.sdk/mb1_test/Debug/mb1_test.elf
dow C:/xprj/dual_mb_00/dual_mb.sdk/mb2_test/Debug/mb2_test.elf
----------------End of Script----------------
15:38:20 ERROR  : XSCT server calls should not be made from TCF thread.
java.lang.RuntimeException: XSCT server calls should not be made from TCF thread.
        at com.xilinx.sdk.xsdb.XSDBCommandManager.issueAndWait(XSDBCommandManager.java:384)
        at com.xilinx.sdk.xsdb.XsdbCommandUtils.executeAndRespond(XsdbCommandUtils.java:307)
        at com.xilinx.sdk.hw.internal.HwPlatform.populateCpuInfo(HwPlatform.java:1671)
        at com.xilinx.sdk.hw.internal.HwPlatform.getCpuNumber(HwPlatform.java:1704)
        at com.xilinx.sdk.targetmanager.XsdbJtagDeviceHelper.getJavaProcFilter(XsdbJtagDeviceHelper.java:421)
        at com.xilinx.sdk.tcf.debug.DbRegisterLoader.isMbProcMatch(DbRegisterLoader.java:664)
        at com.xilinx.sdk.tcf.debug.DbRegisterLoader.run(DbRegisterLoader.java:563)
        at com.xilinx.sdk.tcf.debug.DbRegisterLoader$2$1.doneGetState(DbRegisterLoader.java:144)
        at org.eclipse.tcf.internal.services.remote.RunControlProxy$RunContext$1.done(RunControlProxy.java:140)
15:38:20 ERROR  : Failed to update registers information for 'design_mb_1_wrapper_inst_design_mb_1_i_microblaze_0'.
        at org.eclipse.tcf.EventQueue.run(EventQueue.java:95)
        at java.lang.Thread.run(Thread.java:745)
15:38:20 ERROR  : Failed to update registers information for 'design_mb_2_wrapper_inst_design_mb_2_i_microblaze_0'.
15:38:20 INFO   : Context for processor 'design_mb_1_wrapper_inst_design_mb_1_i_microblaze_0' is selected.
15:38:20 INFO   : 'con' command is executed.
15:38:20 INFO   : Context for processor 'design_mb_2_wrapper_inst_design_mb_2_i_microblaze_0' is selected.
15:38:20 ERROR  : Already running
15:38:20 INFO   : Disconnected from the channel tcfchan#7.
Could you tell the way of correct run or configuration of SW or HW?
Thank you very much for the help!
Observer makarau1
Re: Dual core Microblaze XSDK Run/Debug
Hi  Sadanan,
sorry for the late reply :-)
We resolved the issue.
in a multicore debug/run the XSDK cannot/does not select the proper core before downloading the elf.
Namely, the targets are as follows:
xsct% targets
1 xcku040
The elf1 is loaded into the mb#0 (starred), which is OK.
Then the XSDK downloads elf2 into the mb#0 which is still starred !
So the XSDK dos not switch the second core.
We resolved this by creating a tcl like this:
targets 2
dow C:/xprj/dual_mb_01/dual_mb.sdk/mb1_test/Debug/mb1_test.elf
targets -set -nocase -filter {name =~ "microblaze*#1" && bscan=="USER2"  && jtag_cable_name =~ "Digilent JTAG-SMT2 210251A4627A"} -index 0
dow C:/xprj/dual_mb_01/dual_mb.sdk/mb2_test/Debug/mb2_test.elf
rst -processor
con
Here the second core is explicitly selected and downloaded the elf2.
Could you forward this to the Xilinx SW team?
Thank you!
Hi @makarau1,
Would it be possible to move to a more recent version of SDK? It seems like you're running into one of those internal errors that existed few releases back. The warnings should go away too
Observer makarau1
Hi  Sadanan,
xsct% targets
1 xcku040
targets 2
rst -processor
con
Thank you!
Hi @makarau1,
Use a tcl script like this will work. However, the original issue is fixed in the newer versions of the tool, so you don't have to create the a script manually.
Couple of comments on your script.
'targets 2' is redundant, since you're selecting MB#0 immediately after that. Also, selecting a target by its id is not a good practice, while scripting. Targets are assigned IDs as they become available, so the IDs can change.
'rst -processor' should ideally be before dow. You need to run it for both the MB cores
'con' should be run for both the MB cores separately
Your script should look like something below
connect ;# -url is not needed for local boards
targets -set -filter {name =~ "microblaze*#0"} ;# other options are not needed if you have only one cable, jtag device, and MDM
rst -proc
dow mb1.elf
con
targets -set -filter {name =~ "microblaze*#1"} ;# other options are not needed if you have only one cable, jtag device, and MDM
rst -proc
dow mb2.elf
con
