Dual microblaze not detected in Xilinx SDK
 I have done a dual microblaze model in Xilinx XPS. Both the microblazes are not connected at all . They have independent axi bus,axi4lite bus . But only shares a debug module. When I export this hardware specification to xilinx SDK to start a new application project, none of the second microblaze and it's associated peripherals are not detected n xparameters.h. Also linker file is not showing modules attached to microblaze2. Attached is project. Any suggestions to solve this situation is welcome.
With Regards
Shalini
