Dubugging ZYNQ ARM Core with ARM DSTREAM
HI all.,
we are developing a motor drive solution using ZYNQ 7Z045 SOC. we are planning for the developement tools for debugging ARM core in future(if necessary).
My question is
for debugging ZYNQ SOC ARM DS5 with DSTREAM is required???
or can i do it with XILINX JTAG??
what is the advantages and cons i will get with DS5??
is DSTEAM will support only for Dev Board ZC706/ZC702/Zedboard or it will also support custom board???
Re: Dubugging ZYNQ ARM Core with ARM DSTREAM
please check below AR
http://www.xilinx.com/support/answers/50863.html
Thanks and Regards
Balkrishan
Take look into ARs
1) http://www.xilinx.com/support/answers/46881.html
2) http://www.xilinx.com/support/answers/47764.html and linked user guide to it (http://www.xilinx.com/Attachment/ZC702_DS5_2.pdf).
