Dump large memory data using xsct is quite slow
I need to dump a large range of memory(image) and save it to a binary file. If I do it from Xilinx SDK GUI, it needs only 5 seconds or so:
but if I do it in the xsct console using the following command:
mrd -size b -bin -file /home/xiz/frame.bin 0x20000000 3072000
it is reading but takes forever(very very slow)..
Is there any way to dump large memory data with reasonable time using command line?
Scholar drjohnsmith
Re: Dump large memory data using xsct is quite slow
Quick thought,
Are the SDK and the command line tool talking over the same physical interface to the same target ? or is on eover ethernet and one over JTAG
Hi @drjohnsmith
Thanks for your quick reply. When I use the command line tool, I didn't launch the xilinx sdk, so I don't think this is a problem.
Scholar drjohnsmith
I was wondering , if SDK uses the ethernet and command line uses JTAG then the speeds will be different
Sorry, I dont use SDK very often,
