EDK 9.1 error in generate system.ace file
Hello All,
I am using 9.1 version of XPS and ISE with proper service packs. I recently bought a XUPV2P board and wanted to create a system.ace file for it using the above tools. I added the XUP board related files from the digilentinc website. The edk command shell in which i usually create the system.ace file gives me errors. I follow simple procedure (ref: BYU Linux) to create the system.ace file just the one i used to create for ML310 board, which works fine
Method::
xmd -tcl genace.tcl -opt xupGenace.opt
where the file xupGenace.opt contains the following:
-jprog
-board user
-target ppc_hw
-hw ../implementation/download.bit
-elf ../TestApp_memory/executable.elf
-configdevice devicenr 1 idcode 0x127e093 irlength 14 partname xc2vp30
-debugdevice devicenr 1 cpunr 1
-ace ../implementation/system.ace
The error appearing in the xygwin shell is (attachment 1 in the site)
I had another computer system in which i had loaded EDK 8.2 with proper Service Packs. I tried to generate system.ace in that one for the XUP board, and it worked. So I thought the problem was with the genace.tcl file of EDK 9.1 and replaced the genace.tcl file in EDK 9.1 with the genace.tcl of the EDK 8.2. Now it gave me another set of error (Attachment 2 in the site).
I would appreciate any thoughts on how to generate system.ace file using EDK 9.1 or if i am missing something really basic.
Please visit http://picasaweb.google.com/narashimanc/EDK_91#  for the pictures of the errors i am talking about. The attachment section in this forum isnt allowing me to attach two files together.
with warm regards,
chakra.
no solutions yet??
I don't have 9.1 installed on my machine.  But I tried with 10.1. It works.
-XF
