08-26-2008 04:29 PM
08-26-2008 06:49 PM
akleica,
This behavior is still present in EDK 10.1.02. I don't see any method to switch this to a relative path.
I suspect many are either:
-using short paths
-using large monitors
-handy with the horizontal scroll bar
You are welcome to open a hotline case and request a CR (Change Request) for consideration of this feature in a future build.
bt
08-27-2008 10:54 AM
08-27-2008 11:23 AM
aklecia,
You are correct that this is in ISE's Project Navigator GUI.
A quick test on my end revealed:
-9.2.04i - doesn't appear to do what I expected
-10.1.02 - works as expected with my brief testing (either full path or relative from the ise project, e.g. ../src/magicbox.vhd)
But this feature does not yet appear to be in the XPS GUI. You case for the CR could reference this feature in ProjNav as an example.
bt
