Anonymous
Not applicable
EDK / ISE license problem
My evalution license expired today, but we purchased a license from Xilinx now.
How do I activate the new license?
barriet
Assuming you are using 10.1 - I would:
-go to the Enitlement Center (https://secure.xilinx.com/webreg/register.do?group=esd_oms) and generate a new registration ID that includes full Foundation and EDK features.
-update your configuration, e.g. Start -> Programs -> Xilinx ISE Design Suite 10.1 -> ISE -> Accessories -> Update Software Product Configuration and enter the new registration ID
Older version of the tools may be slightly different because:
-previous versions didn't have a unified installer and single registration ID (rather they used separate registration IDs for ISE & EDK)
-I believe the Update Software Product Configuration issue is relatively new
That should certainly be quicker than uninstalling and reinstalling the tools.
If you have any issues with the Entitlement Center, I would contact Development Systems Customer Service (not Technical support): http://www.xilinx.com/support/techsup/tappinfo.htm
Cheers,
bt
barriet
Cheers,
bt
