EDK & Vista x64
According to the OS support matrix, here:
http://www.xilinx.com/ise/ossupport/index.htm
Vista x64 is one of the few still unsupported OSes for EDK.  I know the software was just released today, but has anyone had a chance to try it on Vista x64 yet?  Does it not work at all?  Or does it work but is just "unsupported?"  I may be buying a new development machine soon and am trying to decided whether or not to order a WinXP x64 or Vista x64 license with it.
Re: EDK & Vista x64
So in case anyone else was wondering, I installed System Edition on Vista x64 yesterday and have had great success with it so far.  EDK and SDK both run well for the most part, besides infrequent Java errors that I've been able to workaround.  I quickly tested it on my colleague's Windows 7 x64 machine this afternoon and was able to probe an ILA with Chipscope Pro, as well as implement a basic ML605 example system.
Re: EDK & Vista x64
I have installed on win7 64bit today.
Re: EDK & Vista x64
Re: EDK & Vista x64
Hi pcurt, could you try to run a edk sp605 board project with win7 64bit platform.
I have a trouble to run edk on win7 64bit platform. when I run a sp605 board project. it's stall when I generate bitstream. But when I choose spartan3 parts. everything is OK. Seems problem just for spartan 6.
Could you verify on your pc?
