EDK can't create a local IP
When I try to make one of my development IPs local within the EDK (Make this IP Local) it fails with the following errors:
ERROR:EDK:2694 - Unknown error.
Fail to make IP local.
ERROR:EDK:745 - Cannot find the core: engineif, ver 2.00.a in the repository.
I can find the IP in the IP Catalog under the Global Peripheral Repository and the EDK will compile changes that I edit into the source file for this IP.
How do I create a local instance for this IP?
maybe u should put your local ips into the  edk/system/pcores directory.
