EDK help me
"WARNING:MDT - Elf file C:\........\executable.elf does not reside
completely within BRAM memory of processor ppc405_0.
WARNING:MDT - The sections of ELF residing outside BRAMs must be initialized
separately using a debugger, a bootloader, or an ACE file"
my system.mhs :
BEGIN isocm_v10
 PARAMETER INSTANCE = iocm
 PARAMETER HW_VER = 2.00.a
 PARAMETER C_ISCNTLVALUE = 0x81
 PORT ISOCM_Clk = sys_clk_s
 PORT sys_rst = sys_bus_reset
END
BEGIN isbram_if_cntlr
 PARAMETER INSTANCE = iocm_cntlr
 PARAMETER HW_VER = 3.00.a
 PARAMETER C_BASEADDR = 0x24800000
 PARAMETER C_HIGHADDR = 0x24800fff
 BUS_INTERFACE ISOCM = iocm
 BUS_INTERFACE DCR_WRITE_PORT = isocm_porta
 BUS_INTERFACE INSTRN_READ_PORT = isocm_portb
END
BEGIN bram_block
 PARAMETER INSTANCE = isocm_bram
 PARAMETER HW_VER = 1.00.a
 BUS_INTERFACE PORTA = isocm_porta
 BUS_INTERFACE PORTB = isocm_portb
END
BEGIN dsocm_v10
 PARAMETER INSTANCE = docm
 PARAMETER C_DSCNTLVALUE = 0x81
 PORT DSOCM_Clk = sys_clk_s
END
BEGIN dsbram_if_cntlr
 PARAMETER INSTANCE = docm_cntlr
 PARAMETER C_BASEADDR = 0xe8800000
 PARAMETER C_HIGHADDR = 0xe8801fff
 BUS_INTERFACE DSOCM = docm
 BUS_INTERFACE PORTA = dsocm_porta
END
BEGIN bram_block
 PARAMETER INSTANCE = dsocm_bram
END
Please help me to solve this warning , because i think that this warning influence my project....THANK YOU
If your applicaiton is samll to fit into the BRAM, you can use the Linker Script to map your application completely into BRAM.
If your BRAM is not large enough to store your application, you have to map your application to an external memory. Then you can use XMD to download the application to the external memory.
--XF
You are right xiaofeip, but the MHS file shown above does not include any memory controller except for BRAM. This means the considered system may not have any external memory.
Dongtrungtao, does the board you work on has an external memory? (SDRAM? SRAM? ZBT SRAM ..? FLASH ?)
Hope this helps,
Nicolas
Thank you very much..Yes , my board has DDR_SDRAM_32Mx32...but i don't know how use it . I have to use DDR_SDAM_32Mx32 for what (data , sdata.......)because i see that in "linker scripts" have many things ????........And you can tell me "if i completed file "linker scripts" ---> i have to  download project to board ----> open XMD debugger ---> connect target---->dowoad---->run---->my project will complete and on my board will display what i created ????????????????????????/????????????? because i working with TFT and i want it display ASCII ( I found code C about ASCII for TFT on internet)...THANKS
And can you tell me how download application to external memory by using XMD . And i have to uncheck "Mark to initializes BRAMS"or check "Mark to initializes BRAMS"????????? . Because i try to use it but you can see figure
Hello...
1. Uncheck the "Mark to initilize BRAMs" of the project that you want to place in the DDR
2. Use a custom Linker script or if you use the default just put the start address of your DDR to the "Program Start Address Field"
3) Build Project
4) Download bit file and use the bootloop program to initilize the BRAMs
5) Open XMD and go to the folder that your elf file is located (cd..    e.t.c)
6) dow executable.elf
7) run
I hope that helps....
George
Thank your replies , i finished my project . Thank you very much
