EDK10.1 + SP3 -->error occurs while updating bitstream
Problems with EDK10.1 Service Pack #3.
The following errors were found while running [Device Configuration -->Update Bitstream]
Copying files for driver lcd_ip_v1_00_a from
E:\fall2008\classes\FPGAsys\prj03\elab303\drivers\lcd_ip_v1_00_a\src\ to
E:\fall2008\classes\FPGAsys\prj03\elab303\microblaze_0\libsrc\lcd_ip_v1_00_a\
INTERNAL_ERROR:MDT:MdtBas_Common.c:939:1.80.6.40 - Can not create valid UT_DIR object in MakeWriteable
ERROR:MDT - Failed to add write permission for
ERROR:MDT - Failed to copy
Copying files for driver cpu_v1_11_b from
C:\Xilinx\10.1\EDK\sw\XilinxProcessorIPLib\drivers\cpu_v1_11_b\src\ to
E:\fall2008\classes\FPGAsys\prj03\elab303\microblaze_0\libsrc\cpu_v1_11_b\ ...
ERROR:MDT - Error while running "Copy Files" for processor microblaze_0...
make: *** [microblaze_0/lib/libxil.a] Error 2
Done!
How can I cure this problem ?  Any one encountered the similar problem before?
Edwin
I happened to find the almost identical problem description in the Answer Browser (AR #25492) and the solution described in the answer proved to be working.
Any one concerned with this problem may refer to "http://www.xilinx.com/support/answers/25492.htm" for the solution.
No one needs to tackle this problem any more.  Thanks to whoever is concerned about this problem.
Edwin
右键点击我的电脑-->属性-->高级-->环境变量-->添加"CYGWIN"变量,变量值"nontsec"-->确定。重启edk即可。
