Visitor qwaserdf-@._
ERROR: [Common 17-70] Only with two vivado's versions installed
Good afternoon.
fisrt I installed vivado 2018 and I could launch SDK properly.
Yesterday I installed 2016.4 version in order to ba able to try one of the digilent's HDMI projects  examples.
Everything worked properly, till I tryed to launch vivado, when I get the error "ERROR: [Common 17-70] Application Exception: Not found in path: xsdk".
The path is correctly set I guess since I works correctly in the 2018 versión.
How could I checked whats the problem and fix it??
Best regards.
Re: ERROR: [Common 17-70] Only with two vivado's versions installed
Hi qwaserdf-@._
Where does the error comes? I mean, Vivado or XSDK? It seems that Vivado is not launching SDK because it does not find the path, right?
Ibai
Ibai
Oh yes!! My bad, I meant when launching SDK from Vivado. It doesn't find the path indeed. Thanks for answering.
