Visitor barrytough
ERROR:EDK:1907 - NgcBuild failed!
INFO:EDK:2245 - Refer to
D:\microblaze\test\sys_cpu\implementation\sys_cpu_microblaze_0_dlmb_wrapper.b
lc for details.
IPNAME:sys_cpu_microblaze_0_wrapper INSTANCE:microblaze_0 -
D:\microblaze\test\sys_cpu\sys_cpu.mhs line 71 - Running NGCBUILD
D:\microblaze\test\sys_cpu\implementation\sys_cpu_microblaze_0_wrapper.blc
for details.
IPNAME:sys_cpu_clock_generator_0_wrapper INSTANCE:clock_generator_0 -
D:\microblaze\test\sys_cpu\sys_cpu.mhs line 107 - Running NGCBUILD
D:\microblaze\test\sys_cpu\implementation\sys_cpu_clock_generator_0_wrapper.b
lc for details.
IPNAME:sys_cpu_axi4lite_0_wrapper INSTANCE:axi4lite_0 -
D:\microblaze\test\sys_cpu\sys_cpu.mhs line 119 - Running NGCBUILD
D:\microblaze\test\sys_cpu\implementation\sys_cpu_axi4lite_0_wrapper.blc for
details.
INFO:EDK:3509 - NCF files should not be modified as they will be regenerated.
If any constraint needs to be overridden, this should be done by modifying
the data/sys_cpu.ucf file.
Rebuilding cache ...
ERROR:EDK:440 - platgen failed with errors!
make: *** [implementation/sys_cpu_proc_sys_reset_0_wrapper.ngc] ´íÎó 2
ERROR:EDK -
Error while running "make -f sys_cpu.make netlist".
ERROR: synthesizing XPS module failed!
Process "XPS Process: Synthesize XPS Source" failed
Visitor barrytough
Re: ERROR:EDK:1907 - NgcBuild failed!
Someone help me,plz!
Would that be possible to share the MHS of your system?
Can you also try to do a project --> clean all generated files?
--Hem
Visitor barrytough
Thx,I have already solved.The MHS has no problem,just because my antivirus software
Glad to know that the issue is solved. Please mark this thread as solved
--Hem
