Observer ramonal
ERROR:EDK:440 - platgen failed with errors! (Virtex 4 FX 12 LC Developmentboard
My board: Virtex 4 FX 12 LC Developmentboard.
I tried to do the mandelbrot example for the ML 403.
I am working with EDK11.1
When I finished to create everything I tried to generate the bitstream for the download.
But I get the message:
make: *** [implementation/system.bmm] Error 2
Does anyone know how to fix it?
Observer fventrone
Re: ERROR:EDK:440 - platgen failed with errors! (Virtex 4 FX 12 LC Developmentboard
You really need to supply some more information. The platgen errors would help. Or better yet, you might include the build output or attach a text file that has the build output.
FV
Observer ramonal
Hey,
Thanks for your answere. But that is my problem I don't have an output file because I can't generate the bitstream. Now I copied the console with the information during generating the bitstream, but it I think it won't help you and that are 8 pages. I don't know which file I can send you? Thank you very much for your help.
greetings Ramona
Observer ramonal
I started the tutorial again and now I got an error message a bit more in detail:
IPNAME:fcb_v10 INSTANCE:fcb_v10_0 -
C:\ImpulseC\CoDeveloper3\Examples\Embedded\Mandelbrot_Virtex4FX\EDK11.2\system.m
hs line 215 - 0 master(s) : 1 slave(s)
ERROR:EDK:1599 - IPNAME:fcb_v10 INSTANCE:fcb_v10_0 -
   m.mhs line 215 - must have atleast 1 master assigned!
Furthermore I got an error with space overlaping because the adress range for the instance xps_tft_0 is 0x00000000 to 0xffffffff and I also don't know how can I figure out the adress space for that instance.
Thanks again
Ramona
Observer ramonal
The problem was that I forgot to connect the MFCB with the ppc405_0
Sorry, but Thank you for your reply
Ramona
