Visitor kikilinux
ERROR:EDK - while loading XMP file
Hi all,
Can someone please help me with these errors:
[root@localhost loopback_test_nf1_cml]# make
make -C hw bits
make[1]: Entering directory `/home/karin/NetFPGA-10G-live-devel/projects/loopback_test_nf1_cml/hw'
xps -nw -scr genmakes.tcl
Xilinx Platform Studio
Xilinx EDK 14.6 Build EDK_P.68d
Copyright (c) 1995-2012 Xilinx, Inc. All rights reserved.
XPS% Evaluating file genmakes.tcl
ERROR:EDK - IPNAME: axi_interconnect, INSTANCE:
axi_interconnect_memory_mapped_lite_0 - PORT interconnect_aclk not found in
the MPD -
/home/karin/NetFPGA-10G-live-devel/projects/loopback_test_nf1_cml/hw/system.m
hs line 46
axi_interconnect_memory_mapped_lite_0 - PORT INTERCONNECT_ARESETN not found
in the MPD -
hs line 47
axi_interconnect_memory_mapped_lite_0 - PARAMETER
C_INTERCONNECT_CONNECTIVITY_MODE not found in the MPD -
hs line 45
ERROR:EDK - IPNAME: bram_block, INSTANCE: microblaze_0_bram_block -
BUS_INTERFACE PORTA not found in the MPD -
hs line 112
BUS_INTERFACE PORTB not found in the MPD -
hs line 113
ERROR:EDK - IPNAME: axi_uartlite, INSTANCE: RS232_Uart_1 - BUS_INTERFACE S_AXI
hs line 139
ERROR:EDK - IPNAME: axi_uartlite, INSTANCE: RS232_Uart_1 - PORT TX not found in
the MPD -
hs line 140
ERROR:EDK - IPNAME: axi_uartlite, INSTANCE: RS232_Uart_1 - PORT RX not found in
the MPD -
hs line 141
ERROR:EDK - IPNAME: axi_uartlite, INSTANCE: RS232_Uart_1 - PORT S_AXI_ACLK not
found in the MPD -
hs line 142
ERROR:EDK - IPNAME: axi_uartlite, INSTANCE: RS232_Uart_1 - PARAMETER C_BAUDRATE
hs line 133
ERROR:EDK - IPNAME: axi_uartlite, INSTANCE: RS232_Uart_1 - PARAMETER C_DATA_BITS
hs line 134
C_USE_PARITY not found in the MPD -
hs line 135
C_ODD_PARITY not found in the MPD -
hs line 136
ERROR:EDK - IPNAME: axi_uartlite, INSTANCE: RS232_Uart_1 - PARAMETER C_BASEADDR
hs line 137
ERROR:EDK - IPNAME: axi_uartlite, INSTANCE: RS232_Uart_1 - PARAMETER C_HIGHADDR
hs line 138
make[1]: *** [system.make] Error 1
make[1]: Leaving directory `/home/karin/NetFPGA-10G-live-devel/projects/loopback_test_nf1_cml/hw'
make: *** [all] Error 2
Re: ERROR:EDK - while loading XMP file
It looks like you are trying to migrate the design from old version to the newer version , is this correct?
Refer to the AR#32143 which explains the steps to migrate the design  http://www.xilinx.com/support/answers/32143.htm
Hope this helps.
Achutha
I think you are adding interconnect, BRAM and UART for an existing system. The IP's that are shown in the error do not seem to be configured. So i would recommend you to configure the IP's first and then do a Project --> Design Rule Check to confirm if you are good to go to implement the design.
An easier way to do this is to create a blank project and then adding up your peripherals.
--Hem
