ERROR:logical net 'tx_doutb_inj22<9>' has multiple driver(s):
hello,everybody
   When i translate a project in ISE,the fllowing error occured.In the ISE project include a EDK project.the error like this :ERROR:NgdBuild:455 - logical net 'tx_doutb_inj22<9>' has multiple driver(s):
     pin Q on block
   pe/xps_bram_if_cntlr_3_eje/xps_bram_if_cntlr_3_eje/SINGLES_ONLY_SUPPORT.I_SLA
   VE_SINGLE_ATTACH/sig_wr_dreg_22 with type FD,
     pin Q on block
   u_router_ni_top_nwse22/u_router_ni_top/u_ni_injection/u_ram_inj/u_ram_inj_v5/
   BU2/U0/blk_mem_generator/valid.cstr/doutb_i_9 with type FDRE
how can I reslove this issue?many thanks!
Can you have a look at this AR to see if this helps.
http://www.xilinx.com/support/answers/22891.htm
Cheers,
Nan
"Don't forget to reply, kudo and accept as solution."
hello,nanz
I have been try like that way,but it didn't work,Thank you very much!
