jboehler
Edit array in SDK expression window
I try to debug my C-code where I have a bunch of global variables I observe in the "Expressions" window in SDK. While I can edit any regular variable (int/float/...) by just clicking on it and entering a new value, this is not possible for char arrays. Why not and what can I do to be able to adapt the values during debugging?
marcb
Hi @jboehler
I see for a char I can set this with the "print" command from the XSCT window. However, it seems to be necessary to use the decimal ASCII value. For instance the below changes the variable to a 'v'.
print -set mychar 118
try using "help print" form XSCT for more information on the syntax.
marcb
Hi @jboehler
If any of the previous information helped to find a resolution, please mark the helpful post as an accepted solution, for others to find.
